    • Joining nodes when two they collide doesn't work
      1727
      @Raaskot In this case the join can only be done by selecting both nodes (even if overlapping) and using the join command from the context panel (with the Node tool). Should it be an option to join automatically?
      custom rounded corners
      • monsterfox
      1114
      @monsterfox When using custom shapes as corners, the shapes are not "bent" to the corner angle. They are just attached. If you need proper rounded corner, use the default corner type.
    • How to extract a part of an object.
      1450
      I just sent the file.
    • E
      How can I write freely in Arabic in the VectorStyler ?
      • ehab
      993
      @ehab In the Paragraph panel menu, select Direction -> Right to Left and then align the text to right. The OpenType typography features should work automatically (but can be selected in the Typography panel also). This example is using the Times New Roman font on MacOS: 0_1754722023500_arabic2.vstyler
      Pattern Brush imported from Illustrator
      pattern brush illustrator • • brentpruitt
      1599
      @brentpruitt This should be fixed now.
    • In isolation mode the path appears non-edible. What to do?
      1959
      @VectorStyler Cool!
      Document storage issues with VectorStyler
      • lihongfu
      1578
      @lihongfu This has been an open bug for some time. I will try to find a solution.
    • How do I copy an Image Effect or style from doc 1 to doc 2?
      1962
      @Raaskot said in How do I copy an Image Effect or style from doc 1 to doc 2?: A minor request for new users: Copy/Paste option included in pop up would be a help though ... I will add this for 1.3
    • Path brush tool will occasionally fill in the unselected shape below it when set to "create new"
      1323
      @VectorStyler Awesome! I'm glad you might have a solution for this. I twill greatly help the use of the path brush
    • How to convert enveloped effects to Curves?
      1337
      @VectorStyler Got it. Makes sense
      Is it possible to suppress a Shape Effect via a Shape/Mask Role ?
      3541
      @Subpath I used displacement effect for this. I will find some time in the next few days to record it.
      Line Width tool options?
      • asan
      5068
      @monsterfox said in Line Width tool options?: Could this display function be added? I added this to the backlog
    • Can't save
      1967
      @VectorStyler Understood. I will back up that folder regularly. The following data xxx.settings xxx.vstool xxx.vswork may be modified by updates, so even if you back it up, there is no guarantee that it will be 100% inherited.
      Where to disable the Selection Frame which follows the Shape form ?
      2088
      @VectorStyler Thank you
    • How to make VS remember last used brush/pen tool colors, widths ...
      4409
      @VectorStyler thank you for having included that on last release. This saves me a lot of clicks
      custom toolbar
      • monsterfox
      1500
      @VectorStyler There are still many functions that don't seem to be in the list of custom toolbars. Maybe the factor you considered is that these are used less frequently. However, the functions of horizontal and vertical average distribution are used quite often, and it's hoped that they can be added to the list.
    • Prevent distorting round corners – how?
      2589
      @VectorStyler Very good, thanks! Yet I think as an user this UI issue is utterly tricky: I'd never guessed to open the (1) Appearance Panel and (2) select Fill-item and then (3) pull the menu to click the (4) Transform Content option without your help I'd expected this in the RM-popup on object instead. Then I could check and compare for object issues. Perhaps with an other name than just "Transform Content" since this also includes the frame?
    • Syncronization don't appear with other fonts of the same style
      1839
      @Raaskot Those values (red marker) are part of the Paragraph Styles.
    • Update defined character and paragraph styles, how?
      2178
      @VectorStyler https://www.vectorstyler.com/forum/topic/5269/move-character-and-paragraph-style-panels-to-text-menu
