    • Syncronization don't appear with other fonts of the same style
      1856
      @Raaskot Those values (red marker) are part of the Paragraph Styles.
    • Update defined character and paragraph styles, how?
      2202
      @VectorStyler https://www.vectorstyler.com/forum/topic/5269/move-character-and-paragraph-style-panels-to-text-menu
    • Bounding box around text / objects
      3482
      Thanks guys! Next time, instead of asking if a feature is available, I will immediately ask where to look for it.
    • E
      Copy-Paste between applications - maintain object size
      • EricP
      1969
      @EricP I opened a bug on this. Groups / layers should be copied correctly.
      Content Crop tool - How does it work?
      • Kumr
      1352
      @Kumr Must be used on images or linked PDF objects
      New Document Setup
      1390
      @B-Vs-V When using the select folder, the options are hidden by design. There is an error here with the name for the "preset" list.
    • Commas vs dots in numerics. How?
      2508
      @VectorStyler Same here, cool, thanks
    • O
      having problems printing to manual feed tray
      • omegamasks
      1655
      O
      @VectorStyler thank you for looking into it. I did get around it by printing to file and then opening that in Preview and printing from there. Preview prints it just fine. Hopefully one of us will be able to figure out what's going on here! In the meantime, I'm loving VectorStyler. It has a lot of the features I've been missing from my old Illustrator + Astute Graphics workflow. Thanks for producing such a feature-rich drawing program!
      How should position adjustment in the Repeater work ?
      4012
      @Li-Xiao Wow, pretty pretty cool. I need still a few more tries to figure out how "Adjust Position" works. It's still unpredictable for me at the moment. By the way, since I used to work as a screen printer for a few years, I'm familiar with moiré patterns that can occur with halftone printing or overlapping Screen folie. Always found them interesting. I had a few ideas after watching your video. One was that if you use red and green dots and some of the old 3D red-green glasses, you might be able to see a 3D effect. But I've also seen many other uses. Again, thank you very much for your help and the insights you've given me and I'm sure other users will be grateful to you for that too.
      Hide color bar
      • asan
      1793
      @Subpath Yes, it is a bug. Must be a recent regression
    • How to keep same overall stroke width on object resize
      3801
      @Raaskot Clearly a bug, can be replicate here also. It occurs with small shapes where the width is large relative to the shape size. I will fix this ASAP.
    • R
      App won't startup
      • Retrograde
      2133
      R
      Thanks VectorStyler, the latest update seems to have fixed whatever the issue was. Cheers!
    • Why does alignment horizontally also alter placement vertically?
      1751
      @Boldline The alignment Angle seems to be set to -90 degrees. With this, all alignment is considered at a -90 degree rotation.
    • Freezing object with effect ... bug or user error?
      1421
      @Raaskot The file is very slow here also. I opened a bug on this to find out what can cause this.
    • How do I remove a brush from the brush preset list?
      4411
      @Raaskot said in How do I remove a brush from the brush preset list?: For my part the Brush Presets list is empty. How comes? This may depend on the current workspace state, there can be multiple brush presets panels and some may end up empty of the associated group is removed. Is there a "Reveal Hidden Presets" in the panel menu? If so, select it. Otherwise, see what panel gets opened with the Panels -> Presets -> Brush Presets command.
      1.2.074 updated and File menu broken
      • MikeI
      2069
      @VectorStyler Excellent, thanks! I'll try to remember to search first next time
    • If document file settings are modified during file use to save history, Can file be saved with current history including whatever was previously recorded during that open session
      1688
      @Boldline The history of changes made before turning the option on might be lost.
    • E
      Blended Shapes : how does it work ?
      • EricP
      3449
      @EricP I opened a bug on this and will try to replicate it.
    • E
      Stroke blending
      • EricP
      2934
      @VectorStyler thank you for the fast turnaround in fixing this bug
    • Eraser setting altered the way eraser works - deletes whole objects now
      2139
      @VectorStyler it was at "0" ok that explains it. When I make it any other size, it returns to the right functionality. Ironically, I can see that being a useful option on occasion - the ability to click or drag on the shape and the whole thing erases immediately. Thanks for your help!
