    Pattern Brush imported from Illustrator
    pattern brushillustrator
    3 Posts 2 Posters 2.0k Views 2 Watching
    • B Offline
      brentpruitt
      i have a number of projects that use illustrator pattern brushes which do not import as expected into VS.
      illustrator pattern brush settings
      it appears that the end, start and corner segments are ‘flipped’ in a manner that i am not sure how to correct within VS. the corner segments are disproportioned. the closed circle path becomes duplicated.
      Is this a bug with the import of the pattern brush?
      i'd like to understand how the elements of the illustrator brush are being interpreted by VS. I am not sure how to edit the pattern brush settings in VS to fix the display problems.
      Org:
      Illustrator file
      VS:
      VS file
      Path Elements
      in the illustrator file, i’ve dragged the existing pattern brush [from the Brushes Panel] to the canvas. i then created the swatches and symbols from those brush components. the sample paths show revered, angled and a closed circle.
      Files
      due to file size upload limitations, i uploaded the sample files to my cloud:
      https://brentpruitt.com/poof/s/vs-pattern-brush
      the example illustrator file contains one of the brushes that does not import as expected. the vectorstyler file is the direct conversion of that file [open, then save the .ai file as .vstyler].
      thanks for your assistance!
      💾 VS v1.2.076
      💻 MacOS Sonoma 14.5
        VectorStyler @brentpruitt
        @brentpruitt I opened a bug on this, and I will try to replicate and fix as soon as possible.
          @brentpruitt This should be fixed now.
