      Path Brush tool with direct live drawing preview and few smoothing?
      • littbarski
      1076
      @littbarski said in Path Brush tool with direct live drawing preview and few smoothing?: when the program starts it says the trial is expired, I think the previous reset period was in the spring. I will try to reset it for you next week.
    • E
      Rotation goes crazy
      • eobet
      1158
      @eobet said in Rotation goes crazy: Hello! Here is the file, but as I mentioned, once I made "save as copy" and opened it, the issue went away. 0_1760094506577_rotation.vstyler Got it, thanks. I will try to have a fix for this ASAP.
      Satisfy my curiosity.
      • monsterfox
      1322
      @monsterfox Guess we’re both out of wishes! We'll all have to let the genie finish coding instead.
    • Make Contour and drawings that was lost
      722
      @Raaskot I will try to replicate this.
    • How do I change the color of a repeater to a different single color?
      849
      @VectorStyler Great! That works. Thank you for explaining.
    • Should Eraser keep selection Active?
      914
      @VectorStyler I apologize, I realized I must have switched it away from "selection" to "layer" when testing and did not switch it back as I thought I had.
      How to align multiple items perfectly following a circular path?
      follow path • • pilkafa
      759
      @pilkafa There is text on path, but does not result in this precise image. You can do an Align Object to Path with the Alignment panel. use Split Text to separate the characters, then group the 10 make sure you uncheck the Rotate Objects and you can adjust the position along the path using the last icon in the row https://share.cleanshot.com/Dy1pfhcV BTW: the Alignment panel functions can be revealed with the up/down knob in the panel title
    • The vector direction handles freaks out when drawing
      942
      @VectorStyler Thanks. That's correct, but the initial path will jump (wildly) out the position with Reset Center command. Its easier to click last freak node, enter 1 and continue with node setting straight lines with pen tool. Not elegant, but it works,
    • How to rotate an object around an offset pivot?
      • syllie
      1459
      @VectorStyler Oh! interesting. I only enabled that to make testing of your first approach easy. Without that rotation knob, and the pivot point knobs in the transform panel deactivated, it works exactly as you said. Thanks for getting back on this.
    • Deformation mesh: some nodes and handles don't work
      915
      Affirmed. Though moving the layer is a fix for the nodes, the handles and (sometimes) deformation lines are still not available
    • I can’t make the line thickness small enough in sub level group
      749
      @Raaskot this is not possible, as the stroke is added and does not override the stroke inside the group. You need to remove the stroke from the object that is inside the group, to make the parent stroke thinner. There is a bug here, with hiding sublayers if a style was specified in the parent layer. I will try to fix this.
    • Shapes. Switching off display of outline when selected
      3453
      @VectorStyler Got it. Cool.
      Could the brush color also be taken ?
      1526
      @EricP There was an old program called "Creature House Expression" that had a similar version back then. There, you could simply select a previously drawn brush with the brush tool itself, and the brush tool would then continue painting with that brush. But i like the VectorStyler way via Ctrl-Key a little more. Because it offers some more possibilities with other Tools too. Here a Video, i still have a copy of "Creature House Expression" works fine with win 10.
    • How to align text with ascenders and descenders?
      829
      @Boldline In the Snapping panel menu open Snapping Options and enable Snap to Path Boxes (second column around the center). This will create separate snapping positions for each glyph
    • R
      How to use pen tool to draw Quadratic segments?
      • razcrux
      2548
      R
      If you go to this URL: https://boxy-svg.com/ And then click on the round spline tool with the single dot [see screen shot] you can see what drawing with a 3-point curve looks and feels like. It is really good for making vectors that are NOT tracing. Bezier curves with the handles are better for tracing existing images, like using a transparent layer. I would be the happiest man on earth if 3-point curves came to VectorStyler. image url)
      Is Vectorstyler able to warp, perspective or other kind of manipulations on bitmaps like transparents pngs, or similar?
      • marce
      2169
      @marce I will try to replicate this.
    • Can we add the ability to sample a color from the artboard itself and then use it as the color choice for the path brush, etc?
      1050
      @Boldline I added this to the backlog
    • Why does my pattern brush have uneven gaps?
      895
      @Boldline I will try to improve this, it can also be replicated here
    • What is the function of "Dimming"?
      1140
      @Raaskot Works when the Template Layer button is checked. (should be disabled otherwise, I will fix that)
    • Reset/remove gradient meshes in shape, how?
      1461
