    • RaaskotR
      How to use color picker in color panel?
      @Li-Xiao @VectorStyler So cool. Thanks. Now I got it (this image for my own VS-guide): [image: 1736336590071-68ac48da-3501-45cd-a08c-fb1a84bed344-image.png]
    • D
      Wide Color Gamut
      D
      I appreciate the quick response. I have attached the Display P3.icc file. It is part of the macOS system. I tried the 16-bit setting in Display Options, but there was no change in VectorStyler. Regards, David Brown 0_1735939455626_Display P3.icc.zip
      1.2.054 update caused dark interface with menus/menu texts invisible (also dark), how to return to light interface?
      @VectorStyler said in 1.2.054 update caused dark interface with menus/menu texts invisible (also dark), how to return to light interface?: @Arte said in 1.2.054 update caused dark interface with menus/menu texts invisible (also dark), how to return to light interface?: After deleting the backup config file it worked normal again. was this the "config.ini" file? Yes
      Software interoperability
      @VectorStyler 22.0.1
    • E
      License verification failed
      FWIW, I had the same error when I registered just now on a separate machine and it claimed server couldn't be connected. I hit Retry and heard nothing back, saw it had the "Remove License" option in the Help menu... on restart, no nag screen, so I guess it is registered...
      How Do I select tints and original spot colors at the same time using the Select menu?
      @VectorStyler said in How Do I select tints and original spot colors at the same time using the Select menu?: But I can try adding support for spot color tints. I appreciate your willingness to try it and see if it's possible. That would add a lot of power to my workflow and keep things consistent on the artboard; there wouldn't be some tints maintaining their spot color info and others that look the same not having any connection
      Can the Repeater create halftones or other repeaters based on the amount of opacity or tint?
      @VectorStyler yes that makes sense about the single color. Could that also work if the tints of the single spot color are moved to a different layer by themselves and the main layer turned off?
      If I delete a palette color, does it only delete from that specific panel?
      @Boldline said in If I delete a palette color, does it only delete from that specific panel?: VS is essentially warning me that deleting the color from the palette is a permanent change to that specific color palette. Yes
      Rename "Select" to "Select Unused" or "Select Unused Colors"
      @Boldline I will make this change.
      I noticed a few things when using the Eraser tool.
      @VectorStyler thank you, as i wrote a square would be totally fine for me
      A symmetrical figure, rotated by an unknown angle. How to adjust the angle to normal level? Or how to measure the angle of two anchor points?
      33
      49k Views
      @monsterfox I have this in the feature backlog for 1.3, I will tyr to bring it forward.
      Option for a major space saving UI layout when using small screen devices like laptops
    • RaaskotR
      Node tool, drag select - short key: How do I select and activate every nodes in same shape?
      @Subpath Would make sense with "-" --> node reduction, but it doesn't seems work. And odd: It appears the reduce node function actually works yet on and off only. As if you must deselect and reselect the shape everytime. Strange ...
      Function absence.
      @VectorStyler https://www.vectorstyler.com/forum/assets/uploads/files/1720881867265-mmexport1720881249980.png I mean this problem. The horizontal panel doesn't show the other three checkboxes.I'm used to the horizontal layout. It's very inconvenient without that checkbox.
      Pencil / Brush tool keyboard shortcuts
      @Harry This is not available in the pencil and brush tools, but I will add it for the next build.
    • RaaskotR
      Calculating a centerline in VS?
      @VectorStyler Agree, but if the object is closed, meaning hollow (like ie. o's or b's), and more complex, like a freehand drawing, it's too complicated to perform this.
      Is there a setting that adjusts the sensitivity of the eyedropper tool when sampling colors in a document?
      @Boldline said in Is there a setting that adjusts the sensitivity of the eyedropper tool when sampling colors in a document?: @VectorStyler What is it picking from when there is no shift modifier? With no shift, it will search for an object pointed by the mouse and pick the style of the object (not just color, but also gradient or pattern).
      A Curve/Path made from a Letter need to be ungrouped before i am able to apply a blend
      @Subpath Yes, text will convert into a group of objects, one object per glyph. I will try to find a solution for single glyph case.
      "Convert to curve" will not be deselected
      “Ungroup” and “Break apart” are displayed even if there is no such thing
      @VectorStyler ok
