    The problematic text crashes when moved
    3 Posts 2 Posters 3.5k Views 2 Watching
    • L Online
      Li Xiao
      I cannot replicate this problematic text. Resolving the issue with this text simply requires refilling the colors. This problematic text randomly crashes when moved.
      0_1729875054851_TEXT ISSUE.vstyler
      https://youtu.be/QvVJtBgiMgA
      https://youtu.be/Abbq6MWy75k
      https://youtu.be/ZaD4Y9KdRkg
      https://youtu.be/mxC_ZUiUkbE
        VectorStyler @Li Xiao
        @Li-Xiao Open the Appearance panel and select the whole text with the text editor.
        There is a "Brush" style on the text. The brush width is 31.9 pt and the font size is 28 pt.
        Stretching a brush of this size on those curves creates the problems.
        I recommend removing that brush.
        I will try to replicate the crash (and look into the crash logs also).
        • L Online
          Li Xiao
          @VectorStyler I forgot to check the appearance in text editor mode. now I understand. Thanks. I'll send the crash logs file to you.
