    3. VectorStyler 1.2 beta
    • The text on a path alignment is set to "center", but is not showing true center of font
      2595
      @Boldline What font is used here? The centered alignment should be about half between the ascent and descent, but it might vary based on the font.
      New document - Doc preset
      2221
      @VectorStyler The issue is quickly solved, I simply reintroduced the correct parameters.
    • beta 1.2.014
      • VectorStyler
      9534
      @Pat said in beta 1.2.014: @VectorStyler Once I've selected an object with the Shape tool, I can no longer modify it with the Node tool. A "Convert to Curves" will make the shape editable again.
      New document's artboard not visible/centered
      4566
      @Harry No problem, it was still a bug, as it should have centered the view regardless of the resolution. The bug will be fixed in the next build.
      Path Dash, Stripe and Profile not highlighted in blue in Stroke panel
      2207
      I personally prefer highlighted values
      How do I get rid of strokes on traced and exported images?
      3446
      @Harry I misunderstood, thinking the issue is strictly related to export (the settings I suggested are found in the Export window).
    • Create divide between "Drawing Place" Icon and "Snapping Tools" icons
      1951
    • How do I hade the outline around the clipped composite shape?
      1842
      @Boldline I don't get this outline in the example file emailed earlier. What is the active tool when this outline is shown?
    • Why does the background change color and give a flash effect each time a node is moved or edited inside a clipping group isolation?
      1582
    • How do I edit an isolated shape inside clipping mask?
      2556
      @VectorStyler said in How do I edit an isolated shape inside clipping mask?: Isolating and Node tool should work. ok I got it to happen again where it dialed down to a specific path. At that level, literally no tool will function.
    • beta 1.2.013
      • VectorStyler
      7454
      @Pat You need to download and install manually, the version was not incremented for this fix.
      Customization, application menu
      2375
      @VectorStyler @b77 Thank you, my double click was too fast. Got it now
      Appearance panel "FX"
      • MajorTom
      2356
      is the third icon from the left
    • Double tapping the "L" key often switches to the Path Sketch tool
      3106
      @VectorStyler sent the files...but realized it may have just needed a reboot of VS (it had been open for a day) because now it's working fine with both the default and the custom settings installed. I'll let you know if it comes up again.
    • Path Brush option to toggle rope option not visible to me on 16 inch mac laptop
      2986
      @VectorStyler ok that makes sense and that worked. thank you
    • Add an option in "Document Setup" to save current configuration as a new template option?
      7036
      @VectorStyler said in [Add an option in "Document Setup" to save current configuration as a new template option?] Some of these features are a combination of several options and maybe not well documented. It's not for me to say , but the lack of case studies makes it difficult for me (perhaps others) to read the documentation. It would be good to include an example of the various aspects of using VS and its multiple options, such as the uses of the document setup options, the use of guides/grids options, of different canvas (reference and others... still to be studied), etc. In my humble opinion, this would help some users to master the various options and use VS by default
    • Scaling up or down live text feels very jumpy
      1596
      @Boldline I opened a bug on this one.
    • Add "Duplicate" function to Right-Click menu options in New Document Setup"
      3772
      @Boldline I will add the preset saving option to the New Document Setup view also.
    • Link to Preset Manager from New Document Setup Panel?
      1518
      @Boldline Scroll down on the right side and there is a more options button.
      Adjusting a text frame to fit the text
      7940
      @861475_VctSt I added these to the task.
