    3. VectorStyler 1.2 beta
      Shape Paint irregularities
      So far so good in VS 1.2.0.25. The Shape Paint objects are updating perfectly after transforming. Thank you @VectorStyler!
      Scaling artwork/text from the centre is a hit-and -miss
      @William-Kansepa I think the difference (to other apps) might be that in VS you have to press the Control after the scaling started. Also: it is possible to customize the key in Preferences -> Modifier Keys -> "Centered Adjustment" row.
      Corrupted files after exporting / pasting
      @William-Kansepa said in Corrupted files after exporting / pasting: Exporting artboard at 300dpi is working, but at 400dpi the previous challenge still persists I will try to replicate this.
      Canvas Guidelines duplicated in panel
      @William-Kansepa I added this to the backlog.
      Assigning a fill colour to a text frame
      @VectorStyler I forgot to mention that it is fine with the Transparency/Color panels (same values). It is only the Appearance panel that is not showing any effect.
      Image Limit Cannot be Set Below 8 MB When Exporting
      @gotanidea I opened a bug on this one.
    • AyoA
      Transform Selection Node sizes
      @VectorStyler Mac Studio + Studio Display 27" default resolution, macOS ventura 13.4.01
      Right Alt (AltGr) acts like Control key while in Text Tool
      @VectorStyler In my case, everything is currently working as it should. Edit: I don't know why , but now, have the same issue as @Harry. Just opened browser to write post here than returned to VS and since that have to use shortcut twice. Edit 2: Ok, I know why it worked in my case. AltGR + Letter works properly only for the first character in text field - any further require double use. I was typing 'Ą' , than delete and typing 'Ć' and so on.
      There is a bug in the Blended Shape Style feature
      @VectorStyler Understood, it's good as long as the program doesn't crash.
      Alternative Option to Knife Tool Break Apart for objects with a negative space Needed
      @Boldline Got the file, I will try to replicate this.
    • LoginErrorL
      Bug report: Recursion breaks layer display
      LoginErrorL
      Noted, thank you.
    • LoginErrorL
      Bug report: Dragging a group of panels on top of their original location causes them to vanish
      @LoginError I opened a bug on this one and will try to replicate it.
    • encartE
      VS highlights current selected font only for installed font
      @encart This issue can be replicated here, and the fix will be in the next build.
      VS doesn't save color setting after restart
      @Harry This is a bug, and can be replicated here also. I will try to fix this ASAP.
      The text on a path alignment is set to "center", but is not showing true center of font
      @Boldline What font is used here? The centered alignment should be about half between the ascent and descent, but it might vary based on the font.
      New document - Doc preset
      @VectorStyler The issue is quickly solved, I simply reintroduced the correct parameters.
    • VectorStylerV
      beta 1.2.014
      8 Votes
      18k Views
      @Pat said in beta 1.2.014: @VectorStyler Once I've selected an object with the Shape tool, I can no longer modify it with the Node tool. A "Convert to Curves" will make the shape editable again.
      New document's artboard not visible/centered
      @Harry No problem, it was still a bug, as it should have centered the view regardless of the resolution. The bug will be fixed in the next build.
      Path Dash, Stripe and Profile not highlighted in blue in Stroke panel
      I personally prefer highlighted values
      How do I get rid of strokes on traced and exported images?
      @Harry I misunderstood, thinking the issue is strictly related to export (the settings I suggested are found in the Export window).
