    3. VectorStyler 1.2 beta
    • beta 1.2.010
      • VectorStyler
      13652
      @FastVector said in beta 1.2.010: @VectorStyler said in beta 1.2.010: Show separators in color swatches Is it possible as a user to turn off the separators? I personally preferred it without the separators as it looked cleaner and was easier view. The only time it was more of an issue was if the swatches in a section were very close in color
      The issue with flipping symbol objects within a clipping frame
      • Li Xiao
      9075
      @VectorStyler fixed. thanks
      The issue with the automatic refresh of cloned shapes
      • Li Xiao
      4374
      @VectorStyler Perfect, everything has been fixed.
      Symbol + Customize corner shape + Repeater causing program crashes
      • Li Xiao
      4133
      @VectorStyler Fixed. thanks
      The bug causing program crashes when using Elastic Warp
      • Li Xiao
      4867
    • Rounded dark theme white outline
      3014
      @Ingolf I will try to replicate this issue.
    • TAB key to change fields in Document Setup screens
      • Victor Vector
      2830
      @Victor-Vector said in TAB key to change fields in Document Setup screens: In the File > New Document Setup window or the File > Document Setup window, using the TAB key to switch fields within the interface will "skip" fields and not go to what should be the next field. These seems to be a bug. I added it to the backlog.
    • File > New Document Setup - Should units update?
      • Victor Vector
      2993
      @Victor-Vector said in File > New Document Setup - Should units update?: Margins and Bleed section will still have the old unit and not update. This is a bug.
    • Could there be an option to have the node editor tool not automatically show nodes on hover?
      2838
      @Boldline That option is for not showing nodes when in transform mode. I will make this work for the node editing mode also.
      Repeater feature: space between objects
      4237
      Pat This kind of "touching edges" rendering artifacts exists with anti-aliasing in certain kind of rendering algorithms. I think Affinity has them too. The problem is that I do not yet have a solution that does not degrade the rendering performance.
    • Image Trace handle multiple raster images at Same Time?
      4736
      @VectorStyler By the way, the image trace has improved vastly. I don't remember when you fixed it but it's a lot easier to use and the results are more predictable and useful. I've been using it more frequently than of the stand-alone specialized trace software I bought years ago. Can't wait until the feature requests for image trace we've made over the last couple years get implemented - it will be hands-down the best
    • Transform tool mode needs to be more obvious during active use
      9971
      @VectorStyler said in Transform tool mode needs to be more obvious during active use: @Boldline said in Transform tool mode needs to be more obvious during active use: What was the reasoning to move them out? Too many tools. Maybe I am not fully understanding? I would only move the three additional tools circled here in red into the transform tool on the vertical toolbar Respectfully, most of the tools in the vertical tool bar have more than the three tools that would be in the transform pull-out: Not trying to cause an argument, merely trying to understand UPDATE: playing around more with the other options in that section, I can see how they are all related to "transform" and I can see in part why it was moved
    • D
      Actual Size is larger than actual size
      • DMBrown
      6786
      @DMBrown said in Actual Size is larger than actual size: 5120 x 2880 Yes, this is the same as the iMac. I think there is a bug here somewhere, I will try to fix it ASAP.
    • How do I set the number of digits in the Distance to three?
      6888
      @VectorStyler said in How do I set the number of digits in the Distance to three?: Here if I set the decimal width of Inches to 3 (or 4) in settings it will display with those number of decimals in the offset path view. This solution does work. I set it to 4 decimals and everything is better. It also improves the slider
    • Bug: Offset Amount resets if initially set with slider then edited manually and tabbed away from
      2901
      @Boldline It is a bug and can be replicated here also. As a workaround, remove the "in" part at the end when editing the number.
    • Bug: Settings>Decimal Widths numerical entries change with mouse movement hovering
      3428
      @Boldline Yes, this can be replicated. I opened a bug on this.
    • D
      Artboard Options not restored when document opened
      • DMBrown
      2827
      @DMBrown Clearly a bug and can be replicated here also. Will be fixed for the next build.
      How to modify the nodes of an object defined as a shape
      6278
      @VectorStyler During all my various tests, I certainly applied this effect and forgot... thanks
    • Fonts, Arrows, Bullets Cutoff in drop downs
      • Victor Vector
      4821
      @VectorStyler Yes, in Windows 11, Main display is 3840 x 2160, Scaled to "150% (Recommended)". Second display is 2560 X 1440, Scaled to "100% (Recommended)".
      Issue with stroke width brush
      • Li Xiao
      6156
      @VectorStyler The first issue has been fixed in version 1.2.009, the second issue is still unresolved, as shown in the following images: correct display and incorrect display.
