    3. VectorStyler 1.2 beta
      Could the Extend Path tool be more automatic?
      2677
      @Harry said in Could the Extend Path tool be more automatic?: I'm wondering if snapping works with the Extend Path tool because I find it quite hard to snap its perpendicular knob to another object. Snapping is not supported for now, I will add that. It would be great if Extend Path tool would work fully automatically, like Trim and Join tool, but in opposite direction (Autocad style). Try the trim and join tool with Alt+ swiping over an open path ending. It will try to extend until it intersects another shape.
      Is it possible to add Presets/Styles to Path Brush and Eraser tool?
      3877
      @Harry Not possible to define presets here, but should be easy to add later.
      Cannot delete width nodes in Stroke Profile panel
      6029
      @Harry I opened a bug on this one.
    • Preset list in the Brushes Panel.
      2552
      @861475_VctSt Yes, this can be replicated and it is a bug. Will be fixed for the next build
      Feature request - preview guides
      3421
      @Pat I added this to the backlog.
    • Can I use them together?
      16527
      @VectorStyler ver. 1.1.111 & ver. 1.2.002 Intel Mac I have been using the software for several days. Both the production version 1.1.111 and beta version 1.2.002 are stable. In my small business, simultaneous launches are also stable.
      Bug : No Preview and Crash on "Add new nodes ...." Feature
      5804
      @Li-Xiao said in Bug : No Preview and Crash on "Add new nodes ...." Feature: @Subpath your welcome. I previously bought a macro for CorelDRAW and it has some nice node-related features. http://gdgmacros.com/details.php?prodId=286&category=14 It's a pity, it has stopped updating. Looks interesting As far as I know, CorelDraw has a scripting part. The last time I used this it was Visual Basic, so if some are a little adventurous Btw Scripting is also on the Roadmap of VectorStyler.
    • beta update 1.2.002
      • VectorStyler
      21
      21
      36601
      @VectorStyler I mistakenly set the video private. It is now for public viewing. Please check.
    • UI Theme [Light Grey]
      2681
      @861475_VctSt said in UI Theme [Light Grey]: If you can revert to the original color scheme, please consider it. I will check what changed here. Should be easy to revert.
    • Quick look Preview
      2846
      @861475_VctSt Yes, this is still an open bug.
    • Move it by ⇧+→.
      4239
      @861475_VctSt Got it. Looks like the percentage value is read as 10 pt (not 10x). This is a bug, will be fixed in the as soon as possible.
    • Show center point of object
      3243
      @VectorStyler Thanks You made it easy.
      Issue with the Variable data export
      • Li Xiao
      5492
      @Li-Xiao said in Issue with the Variable data export: Actually, all of about exporting variable data is problematic. Opened a bug on this one.
      Missing links and files in the documentation (docs_v1_2)
      • freggern
      3948
      @freggern Fixed.
    • Toolbox Customisation - arghhhhhh!!!
      2715
      @Igull This is the same as before. The problem is that those toolbox "modes" in the menu are actually different toolbox customization presets that will overwrite the current (unsaved) toolbox. I will try to think of a better solution for this.
    • Keyboard Shortcut(s) Broken
      5139
      @Igull Looks like there is still one issue: the app needs a restart to have the shortcut show in the tool tip. I opened a bug on this one. I will test the toolbox thing also, the problem is that 1.2 has a lot of new tools.
    • Rectangle and oval tool amongst others, are again warping when pulled with the transform tool.
      3098
      @Boldline The stroke width is scaled (a document level option) and it is not scaled uniformly.
      Trim and Join Tool - bug?
      3357
      @Harry Added this to the backlog, looks like a bug.
      Question, how to "Convert Dashes to Curve" ?
      4243
      @VectorStyler , thanks Have overlooked this arrow and the option below it. Thought the arrow might be a bit more prominent ? Hadn't guessed that the option was under Object > Shape. I was looking/searching in the brush stroke panel. But cool to have that option
      Not enough options in "Arrange Artboards" panel
      2577
      @Harry Added this to the backlog.
