Double tapping the "L" key often switches to the Path Sketch tool
Today I have noticed that double tapping the "L" key to make a node a cusp, often switches to the Path Sketch tool. This happens most of the time now and itoccurs whether I tap the "L" key slowly or quickly.
Is there a workaround for this?
@Boldline I try to find out what could cause this. Were there any shortcut customizations?
@VectorStyler I did not change anything intentionally in terms of shortcut customizations, but I did try removing my customized settings file and reverted to the default settings and I'm having no issues now. I can send you that saved settings file I was using prior.
@Boldline Send me those files from the /resources/ folder.
@VectorStyler sent the files...but realized it may have just needed a reboot of VS (it had been open for a day) because now it's working fine with both the default and the custom settings installed. I'll let you know if it comes up again.
