      Grid snapping virtually doesn't work if the grid is angled
      • pentool
      3557
      @pentool Managed to replicate some issues without Align to Pixel. Will be fixed ASAP.
      Crash when ungrouping mask in isolation mode
      • pentool
      2055
      @pentool Added this to the backlog.
      Blend on a path with gradient + dragging blend objects in Layers Panel is crashing
      • pentool
      2485
      @pentool Added this to the backlog, I will try to replicate it ASAP.
      Problems with color sliders (they turn white and not changing)
      • pentool
      3506
      ...also, I'm not in favor of this "feature". I much prefer the SHIFT key to work the same way across all value fields when pressed in conjunction with the up/down arrow keys. (eg increase/decrease the value by 10) If you have to press SHIFT to temporary change the color of the inactive swatch, you might just as well press X to switch to the other swatch back and forth.
      Blend on a path is running away when dragged
      • pentool
      1819
      @pentool Can be replicated here also, will be fixed ASAP. As a workaround, deselect all after assigning the blend path and then select the blend object again. What happens here is that the blended objects are selected twice (bug)
    • New Zoom Issue
      2873
      @Igull There's no joke in it. Maybe the artboard "jumped" because it was trying to center the huge canvas (once you get to a certain level). Will give it a try see if it happens on my end. ...yes, it happens to me, too if the canvas is huge and "Large Canvas" is not enabled.
      Opacity value change in Appearance Palette with SHIFT held down selects palette contents
      • pentool
      2049
      Cannot copy/paste object through layer selection
      • pentool
      3143
      Got it, thanks!
    • Rasterize Failure
      2184
      @VectorStyler ver1.1.1oo We were able to confirm that it was fixed. Thanks
    • Labels do not appear to be different now for compound groups
      2476
      @Boldline Command-8 triggers the "destructive" Combine operation (Object > Combine Path > Combine) which results in a path, not the composite operation which lets you move/edit the objects inside the composite object with the third mode of the Select/Transform tool. Btw, Option-clicking any of the Combine buttons in the context panel triggers the non-destructive Boolean operation instead.
      Zooming-in makes line(s) disappear
      • pentool
      3865
      Color cannot be applied to anything. Text, shapes, etc.... all white.
      • mlappy
      3625
      @mlappy This could also be a color profile issue, that can be selected in Styles -> Color Settings
      More repeater issues...
      • pentool
      1872
      @pentool I added this to the backlog, will be fixed ASAP.
      Repeater seems to have all sorts of issues
      • pentool
      1675
    • VS not retaining saved custom preferences file on restart
      2209
      I've been using custom preferences for awhile now and I have not experienced this so far. Usually when I have to reset something, install a new version (which seems to reset the preferences) I load it back and it stays there for me. How did you "replace" the default settings? You dragged your file into a folder using the Finder or you used "Preferences > Presets > Load from file" option?
      Problems with shape corners
      • pentool
      2533
      I believe I can see in part what @pentool is referring to with the shape panel. It seems to me that there's some repetitive options as you go deeper with the buttons to edit the shape and the one to edit the corners. I started getting confused as to what was different about setting the corners on the surface level compared to going deeper aside from there being a couple other clickable options for inverse, etc Someone may know more and have a better idea, but it seems to me it would make more sense to have these options for the shape itself and the corners as sections of the same panel like the stroke panel is now. The stroke panel covers several stroke options, each in their own open section of the panel
    • Erasing portion of containing shape shifts position of clipped inner shape
      3457
      @Boldline For a workaround: disable "Separate Path with Eraser Tool" in preferences.
      Incorrect selection in Layers Panel when grouping objects
      • pentool
      1692
      @pentool Added this to the backlog/
      Canvas roles are not synced
      • pentool
      1668
      @pentool Yes, can be replicated here also. Will be fixed ASAP.
      Disclosure triangle appears next to object name when trying to rename object after exiting isolation mode
      • pentool
      1959
      @pentool Yes, this happens because when isolating into n object, an empty clipping group inside that object is created. This allows then to draw other objects that are clipped. The problem is, that if nothing is drawn, it just leaves the empty clipping group there. I will try to find a solution for this.
