    • Transform panel proportion lock is not remembering previous setting
      4879
      @VectorStyler ok working now here as well. I don't know what to say lol. I tried it several times before reporting it. Glad it's not an issue
      Panel with long title is jumping when moved
      • pentool
      2570
      @pentool Added to the backlog.
      Grid Editor: Cannot remove grid color
      • pentool
      6018
      @b77 said in Grid Editor: Cannot remove grid color: I hope the 'Clear Grid Color' command in the Grid panel's menu will still be available. It's faster to do it from the panel Yes, it will stay there. The only bug here is that selecting the No color in the palette drop down should work.
      Cannot move color sliders (except in RGB mode)
      • pentool
      4389
      @pentool Added to the backlog, will be fixed ASAP.
      Color modes not updating in Canvas Color dialog
      • pentool
      2580
      @pentool Replicated here also. Looks like the color changes caused a bit of havoc. Will get the fix by early next week.
    • Appearance Stroke slider and selection cuts out early
      3101
      @pentool seems to not be an issue now. I had tried with different files and the like
      Crash when you click on a color slider
      • pentool
      3095
      Sound good, thank you!
      VectorStyler unexpectedly quit
      • pentool
      2510
      Cannot use any other color mode other than RGB.
      • pentool
      4274
      @pentool Replicated the bug here also, the fix will be in the next build.
    • Color slider in color palette does not function properly
      4053
      @861475_VctSt said in Color slider in color palette does not function properly: However, it is my opinion that it does not make sense to have the most recent FILL value in the imported image. Please consider this in the future. I will try to fix this later.
      Shape Editor vs Node Tool
      • pentool
      5751
      @Ayo Correct. Most (if not all) programs call it Node Tool or Anchor Point Tool, etc. So people coming from other programs can relate this way.
      DOCUMENTATION: Shape Builder Options are outdated in the docs
      • pentool
      2696
      @pentool Yes, I will updated this.
      Shape Builder "Gap" redundant?
      • pentool
      2623
      @pentool I think the unit issue needs fixing, but for now I would keep the redundant field. The reason for this: the modal view should contain all the settings of the tool (regardless if accessible elsewhere), and the context panel contains a subset of this (among other things). This pattern is used in other editors also.
    • The navigator panel is grayed out.
      4458
      @VectorStyler Thanks. VS>Panel Reset, solved the problem.
    • Scaling certain blurred objects causes distortion instead
      6593
      @Boldline said in Scaling certain blurred objects causes distortion instead: Is this something a modifier key coinciding with the transform tool could be used to achieve? This is not related to the transform tool. It only occurs when noise is used in an effect
      Locked icon for artboard size doesn't update value
      • pentool
      3349
      @pentool Added this to the backlog, will try to replicate it.
      NOT QUITE FIXED: Default document canvas size not honored until you specifically set the canvas size
      • pentool
      2785
      Blend: smooth is not smooth
      st an unoptimal feature • • B-Vs-V
      21
      21
      40262
      @Pat I will try to fix these crashes.
      Font problem in imported PDFs
      • mickrose
      4574
      @VectorStyler The update 1.1.095 is much better now with importing PDF file. There are still a few bugs and I will try to clarify these in the next few weeks.
      Grid Panel doesn't work (?)
      • pentool
      5704
      @pentool I think this is more like a usability issue. In this case, there is no grid in the new document so it cannot be shown (maybe it should create a default one when show grid is enabled). A grid can be created using the Grid panel menu Create... commands Also, in the Grid panel menu there is a Select Grid submenu, that can be used to select the active edited grid in the panel.
