Labels do not appear to be different now for compound groups
  • @VectorStyler said in update 1.1.100:
    Show composited groups with a special label in the layers panel.
    Am I missing the label? I have an example of a compound grouping and a singular object, but both leayer labels look the same in build 100.
    0_1692048412373_c6741bba-9fb8-4894-aa94-489f7406d8b9-BLD 2023-08-14 at 17.24.46.png
    Even if I group two compound paths that are each grouped, I get a standard "group" label
  • I get the word "{Composite}" in the Layers panel.
    Select 2 objects > Object > Composite Shape > Compound
  • @pentool ok I figured out the issue. If I use the Object > Composite Shape > Combine, I get the intended result. If I use the shortcut for the same thing, command-8, it makes a compound shape but does not register it as such in the layer panel
    Here is a video showing this
  • @Boldline Command-8 triggers the "destructive" Combine operation (Object > Combine Path > Combine)
    which results in a path, not the composite operation which lets you move/edit the objects inside the
    composite object with the third mode of the Select/Transform tool.
    Btw, Option-clicking any of the Combine buttons in the context panel triggers the non-destructive
    Boolean operation instead.
