      Disclosure triangle appears next to object name when trying to rename object after exiting isolation mode
      • pentool
      3769
      @pentool Yes, this happens because when isolating into n object, an empty clipping group inside that object is created. This allows then to draw other objects that are clipped. The problem is, that if nothing is drawn, it just leaves the empty clipping group there. I will try to find a solution for this.
    • Exclude problem when objects are in a group
      2736
      @encart Yes I think this is a bug, will be fixed ASAP.
      Graphic tablet - Still no tool tips after hovering over the icon
      2797
      @Harry said in Graphic tablet - Still no tool tips after hovering over the icon: But still, there are no tool tips after hovering over the icon with the stylus. I will try to fix this.
      Artboard incorrectly rotates when the Canvas and then the Artboard is selected in the CAP
      • pentool
      4660
      @pentool Think of it as a large desk, with various sized papers on it, placed at different angles. Sometimes you rotate the papers on the desk (rotating the artboard), and sometimes you go around the desk to have a different view (rotating the view).
      Haze effect applied to a lettering …
      • Buntstift
      8012
      @Buntstift Cannot replicate the Bloom effect problem. What are the export settings? An example file saved after exporting (export settings are stored with the vstyler file) would help replicate this issue.
    • Path Brush Tool Not Accepting Color Direction from Sampled Colors
      4519
      @Boldline Use the color picker from the color panel.
    • Editing clipped shape causes obscured sections to flash each time
      2929
      @Boldline Yes, this is a temporary refresh issue. I will try to find a solution.
      Adding snapping angles not only have weirdness but also crashes the app
      • pentool
      4955
      @pentool I will try to replicate this crash.
      Weird jumping of minimized panels
      • pentool
      2769
      @pentool Replicted, added it to the backlog.
      New shape goes into wrong layer
      • pentool
      2674
      @pentool Replicated, will be fixed ASAP.
      Adjusting dashes crashed
      • pentool
      3384
      @pentool Replicated the crash, fix will be in the next build.
      Incorrect xform origin for objects after application start
      • pentool
      3865
      @pentool Can be replicated here also.
      Single-column two-column toolbox
      • pentool
      3459
      No, I did not customize the toolbar. Originally (when you install the app) it is a single column. Since I have a 13” laptop I changed it to 2 column. And now I just saw that for some reason it returned to a single column but in the menu still the 2 column is selected.
      HSB coloring doesn't work
      • pentool
      2725
      @pentool yes, replicated here also, same as the CMYK slider error, the slider intervals are not correct.
      Color Panel > the Black (K) component of the CMYK slider stuck on 0 and cannot be moved
      • pentool
      3938
      It's because I'm a bug magnet. I attract bugs. They are coming to me even without inviting them in.
      Action folders collapse once Action Panel is moved
      • pentool
      2634
      @pentool Added to the backlog.
    • "New from Clipboard" does not retain original file's document settings
      4341
      The pasted artwork size was 300 x 300. Not 452.2 x 810.1
      Composite shape will move after "Intersect" mode selection
      • pentool
      5489
      Yay! Beautiful! Thank you!
    • Save + time since saving icon in status bar broken?
      6186
      @VectorStyler said in Save + time since saving icon in status bar broken?: @Ingolf I will try to add a fix for this in the next build. No rush - just an observation that the icon behaves like this.
      Shape Builder keeps crashing
      • pentool
      7159
      @pentool said in Shape Builder keeps crashing: Well, last time I did you said they are not much help because it's difficult to pinpoint the issue. Yes it is difficult, but still the next best thing if cannot replicate it
