    • N
      Style issues ( mega-topic ) ( partially unfixed )
      • Nils
      4394
    • N
      Multiple roles on same object causes confusion applying them ( accumulated )
      • Nils
      3460
      @Nils Added this to the backlog.
    • N
      Pairing role "Object style" with another causes additional empty style ( accumulated )
      • Nils
      4441
      N
      @vectoradmin Right, was doubting the validity of the second one aswell.
    • Convert to curves error message when shape editor is used
      6934
      @Ingolf I open a bug on this one. Could be some UI issue.
    • Vertical Text Tool - Default text flows right to left in English
      • Victor Vector
      3394
      @Victor-Vector The Right to Left settings does not work for this. There is a existing task in the backlog to allow configuring the line flow direction also, that will fix this.
    • N
      Move inside last still displaces object when parent has transform shape effect ( accumulated )
      • Nils
      3048
      @Nils I will keep this thing open.
    • Live text boxes seem more difficult to quickly move
      3474
      can confirm it here. Installed the update yesterday and found the same thing. It also seems to me, as @vectoradmin said thin fonts and also small sizes if you zoom in a bit, you have a better chance to catch the font to move it around
    • Paragraph Style > Labeling > Options > Fill Style Crash
      • Victor Vector
      3648
      @vectoradmin under Label I selected Bullets and chose the asterisk as the bullet style. I am also getting this odd selection behaviour where 3 lines selected displays as two, but the choice only "bullets" one line. Finally the display field for the bullet glyphs is not scaled correctly, and glyphs are missing. Are the missing glyphs due to the wrong font choice on my end?
    • N
      Dragging and dropping panels slightly misplaces them ( accumulated )
      • Nils
      2967
      @Nils Yes, this occurs on Windows.
    • N
      Align to key object ( accumulated )
      • Nils
      24
      24
      38507
      @Nils Yes, changing selection will reset the key object. I will try to find a solution for this.
    • Sometimes VS wants to close every project tab when you choose to close one
      4819
      @vectoradmin I've gotten into the habit of opening VS fresh every day and sometimes mid-day if I've been doing a lot of work, just to help avoid potential issues like this. I don't always do so obviously, and this happens from time to time
    • Blend issues
      3792
      @Boldline Yes, the problem can be replicate here too. It is an error in how one shape is mapped to the other, added it to the backlog.
    • Find Edges does nothing (Windows)
      10457
      @Ingolf If you still have that file, please send it to me. I will try to replicate the crash.
      Gradient can't be applied to brush stroke
      8355
      @vectoradmin oh lovely! Thanks. It even works with just one end set to flat, if that helps with troubleshooting...
    • Numeric Spinner Arrows - Should they all scroll with the mouse wheel?
      • Victor Vector
      4801
      @Victor-Vector Added this to the backlog.
      This topic is deleted!
      Copy/Paste from AD, issues
      7574
      @PatrickM Got the file. Exported from AD into PDF. Observations: some characters and ligatures (glyphs) are not importing correctly (if these are exported as glyph indexes by AD, then it is a lost cause). the gradients behind (P) and (Ca2+) are all flattened to images by AD when exporting. the same issues occur when importing the PDF into AI (2021). Tried the export (AD) then import (VS) both on Windows and Mac with similar results. Exporting in AD into PDF (for export) could be a bit better. I will try to figure out the ligature import issues. But as a workaround, these can be replaced manually once in VS.
    • Brush tool defaults away from top plain brush
      2904
      @Boldline Yes, this issue is still open!
      Wanted to update the Windows version to 1.1.017 while I had an unsaved document open.
      • Gremriel
      4891
      @Gremriel said in Wanted to update the Windows version to 1.1.017 while I had an unsaved document open.: Yes, update went fine when there was no document open. This happened to me too.
