    Style issues ( mega-topic ) ( partially unfixed )
    3 Posts 1 Posters 4.8k Views 1 Watching
    • N Offline
      Nils
      Legend
      Notice: There's a summary at the bottom.
      ( accumulated ) : The sub-topic has been accumulated from an existing topic and marked there aswell.
      ( partly accumulated ) : Aspects of the sub-topic have been accumulated from an existing topic and marked there aswell.
      ( despite { version } ) : The bug / feature is noted as fixed / implemented in the release notes of the version, but is still unfixed / unimplemented.
      CEDIT : EDIT for a sub ( child ) - topic
      PEDIT : EDIT for the mega ( parent ) - topic
      1. Change to applied shape style override doesn't propagate ( accumulated )
      1.1 Description
      This doesn't happen for color styles. Didn't test for other types.
      1.2 GIF
      alt text
      Fixed
      2. Available shape style overrides list not showing any styles ( accumulated )
      2.1 Description
      Clearly I have defined two shape styles in the document.
      2.2 GIF
      alt text
      Fixed
      3. Having more than one role on an object causes additional empty styles ( accumulated )
      3.1 Description
      Here, "Shape" is used as the second one.
      I assume having two roles on an object causes this, because the styles are then named the same. But imo VS should in this case automatically apply semantic augmentation via parantheses, that is "style name" ( Object ), "style name" ( Shape ), to the style.
      3.2 GIF
      alt text
      Fixed
      3.3 Variation 1 : Canvas and object role
      3.3.1 Description
      This also happens when both, the canvas and the object have the same role.
      3.3.2 GIF
      alt text
      Fixed
      4. Multiple roles on same object causes confusion applying them ( accumulated )
      4.1 Description
      As a programmer I already have a strong hunch that this is caused in the backend by object references with the same name. So, because both styles are named the same, VS likely can't choose the right reference. Should this be the case, I'd suggest semantic augmentation of the respective styles via use of parantheses.
      4.2 GIF
      alt text
      Fixed
      4.3 Continuation 1 : Selection indicators
      4.3.1 Description
      • 4.2 is fixed
      • selections that indicate applied styles are wrong
        • only firstly listed style ( color ) is selected
        • doesn't matter which one was applied first
      4.3.2 GIF
      alt text
      Fixed
      4.4 Continuation 2 : Missing available overrides
      4.4.1 Description
      • overrides show only the color part of the source object "multi" as available
      • again, if this is fixed, semantic augmentation via parantheses would be nice
        • multi ( color )
        • multi ( shape )
      4.4.2 GIF
      alt text
      Fixed
      5. Canvas role "Object style" doesn't work, others do ( accumulated )
      alt text
      Fixed
      6. Object style role causes object deletion to not reflect immediately in layers panel ( accumulated )
      6.1 Description
      The same doesn't happen for color or shape styles ( didn't test others ).
      6.2 GIF
      alt text
      Fixed
      7. First change to object style won't propagate ( accumulated )
      alt text
      Fixed
      8. Setting a shape on a group within a group offsets the nested group ( accumulated )
      8.1 Description
      Performed on a new document
      8.2 GIF
      alt text
      Fixed
      9. Copying an applied referencing scatter brush breaks the link ( accumulated )
      alt text
      Fixed
      10. Stroke style role doesn't work
      10.1 GIF observations
      • after the Stroke Style role has been applied, no style appears in the panel
      • as soon as the Color Style role has been applied and the object has been
        given a fill, there appear 2 styles in the panel
        • the Stroke Style
        • the Color Style
      alt text
      Fixed
      CEDIT: Stopped working completely in 1.1.026
      11. Changing or removing override of copied object back-propagates change to original
      11.1 GIF observations
      • duplication mode is "Copy on duplicate"
      • first object without override is copied
      • override is applied to copy
      • copy with override is copied
      • override on second copy is changed
      • override of first copy changes aswell
      • the same happens for removal of override
      11.2 GIF
      alt text
      Fixed
      12. Applying shape to transformed, asymmetrical object not quite right
      12.1 Description
      • applying the shape without the transform seems correct
      • after the object has been transformed non-destructively, the shape doesn't quite seem to end up at the right place ( seems close, but a little off )
      12.2 GIF
      alt text
      Fixed
      13. Applying a shape style from the styles panel still uses incorrect center, via context bar works
      13.1 Description
      13.2 GIF
      Unavailable
      Fixed
      14. Removing shape styles
      14.1 Shape panel doesn't provide a way to select "None" as shape style
      14.1.1 Description
      14.1.2 GIF
      Unavailable
      Fixed
      14.2 Removing a previously applied shape style via the context bar not working
      14.2.1 Description
      14.2.2 GIF
      Unavailable
      Fixed
      14.3 Detaching an applied shape style doesn't remove the shape
      14.3.1 Description
      • whether it was applied through the context bar or the styles panel
      14.3.2 GIF
      Unavailable
      Fixed
      15. Making object names unique after copying, cloning or referencing
      15.1 Description
      • I classified this as a bug, due to it causing various bugs, while not being a bug itself
      • when named objects, groups or layers are copied, cloned or referenced, their names are duplicated as is
      • instead, they should be pre- or suffixed with a document-wide unique identifier
      • this would, i.e., enable one to identify copied or cloned clone sources in the menus
        • this would probably help solving the problem with links to copied clone sources not changing to the copy
      15.2 GIF
      Unavailable
      Fixed
      16. Copying source of clone breaks link to clone
      16.1 Description
      16.2 GIF
      Unavailable
      Fixed
      17. Overriding offset path shape effect on copy back-propagates
      17.1 Description
      17.2 GIF
      Unavailable
      Fixed
      Summary
        Fixed
        Fixed
        1. ( and 2. GIF ) Title
          Fixed
        2. Variation 1 : Canvas and object role
          Fixed
          Fixed
        2. Continuation 1 : Selection indicators
          Fixed
        3. Continuation 2 : Missing available overrides
          Fixed
        Fixed
        Fixed
        Fixed
        Fixed
        Fixed
        Fixed
        Fixed
        Fixed
        Fixed
        1. Shape panel doesn't provide a way to select "None" as shape style
          Fixed
        2. Removing a previously applied shape style via the context bar not working
          Fixed
        3. Detaching an applied shape style doesn't remove the shape
          Fixed
        Fixed
        Fixed
        Fixed
      All fixed
      PEDIT: Added new issues 13. - 16. and adjusted previous status for 1.1.028.
      PEDIT: Added 17. in 1.1.028.
      N 1 Reply Last reply Reply Quote 1
      • N Offline
        Nils @Nils
        This post is deleted!
        • N Offline
          Nils
