      Shape builder tool problems with 1.1.025
      • MajorTom
      5716
      @MajorTom Yes, some of these issues are still open.
      Closing node issue in pen tool
      5892
      Maybe this recording will explain what I mean. In both the program the first and closing node is just a click (and not click+drag). In other program there is no handle in closing node, but in VS there is handle.
    • Font issue after a period of time using VS
      7028
      @Boldline got the files, I will try to figure out what is going on.
    • Paste in place not working - pastes older items copied earlier on
      2935
      @Boldline Yes, this can be replicated. Will be fixed ASAP.
    • Knife tool not always working when an object is not selected
      7191
      @encart I will try to replicate this, here it works on ellipses.
      Text - Rotation Center differs between Original and Clone
      8096
      @vectoradmin ok no problem.
    • Navigation panel allow rotation disabled - but not remembered
      3110
      @Ingolf Added this to the backlog.
      Adjustng stroke width tool , brusgh settings are affected with new strokes
      • gentlecl
      5704
      @Boldline said in Adjustng stroke width tool , brusgh settings are affected with new strokes: Should this happen automatically? Looks like there is a bug in the brush panel, it should be showing the current selected attributes.
    • CPU crash
      • Devil Dinosaur
      2885
      @Devil-Dinosaur The worst type of crash that could occur is when freezing while running on the GPU, this one is not managed (preempted) by MacOS. This may result in a simple logout, or a restart of the computer. Other type of crashes of VS cannot restart the computer since VS is just a regular user space program. Usually, when VS crashes, it saves a crash log that can be sent when the app is started next time. I did not get any crash log on the server regarding this.
      Two crashes in a row after using pensil
      • gentlecl
      2770
      @gentlecl Unfortunately, this type of forced shutdown crashes are not reported by Windows. So if there are some specific steps to replicate this, it would help a lot. One thing that could help is a recording of the whole VS screen with panels open, and the pencil tool being used to crash the app. It might be caused by some panel, or brush type being selected.
    • Duplicating object by Alt + resize handle makes corners asymmetrical
      5169
      @vectoradmin Thank you. I see. So I wasn't sure if it was a mistake. In part, I also wanted to inform the rest of the users what could be the reason for this. Do you think it's a bad idea to add something like 'Reset handles positions' to context menu? Even if the effect would be the same as convert to curves. Maybe for new users who will find themselves in this situation, it would be a help.
    • Reference image pixel movement when adding nodes or editing them
      2862
      @Boldline Yes, this has been reported before, it is still open in the backlog. Will try to fix it ASAP.
    • When applying Levels to an image...
      • Sullyman
      2941
      @Sullyman I could not replicate this, here is what I tried: https://recordit.co/BJQrM9mPFk What was the image format and color mode? Also: what OS you have? Image filtering uses compute, and that might also cause issues on some systems. You could try disabling compute for the document in View -> Display -> Display Options -> Images and uncheck Compute Filtering. Also: there have been reports of issues with grayscale image display. If you have a test file replicating the issue, please send it to me to csraba at vectorstyler.com Thanks!
    • N
      Editing issues ( mega-topic ) ( partially unfixed )
      • Nils
      26
      26
      39727
      @Nils Keep in mind some are just usability issues, where user input is needed — see my last post here, for instance: https://www.vectorstyler.com/forum/topic/1835/how-do-i-selectively-edit-the-height-of-some-of-the-text-on-a-path
    • Second click on node while in pen tool to create a sharp edge?
      7840
      @vectoradmin I sent you an email about how I think this issue and many of the others are related to a conflict in my custom preferences file. Switching to a default one seems to have resolved this issue and a number of others i was running into in build 26. I also just sent you the workspace file I had been using via email
    • N
      Cloning issues ( mega-topic ) ( partially unfixed )
      • Nils
      28
      28
      45706
      N
      @vectoradmin Hey, please check out my last comment on this mega-topic. It isn't the files. I've replicated this with the default files. It's the shape effects panel being active as I described above. This is 100% the cause.
      Blend misbehavior
      4216
      @vectoradmin no, it does nothing. my workaround is, to use Blend from the Panel Menu, or i convert the Curve to straight line with the Shape Editor Tool.
      Symbol selection issue with new tools
      • fde101
      15421
      @fde101 There is no limitation on have the same symbol size. What happens here is that the newly inserted symbols will get the same transformation form the symbol set. I will figure out some solution for this.
    • N
      Application issues ( mega-topic ) ( partially unfixed )
      • Nils
      4347
    • N
      Symbol issues ( mega-topic ) ( partially unfixed )
      • Nils
      3605
