Dashed Line Align to Cusp Artefact
When using Dashed Line Align to Cusp and using thick strokes I get the artefacts shown in the picture below.
I can confirm that the problem can be replicated.
It is a bit hard to say when a fix will be available, this seems to be a much harder issue related to fix.Artifacts may occur when the length of the dash at a cusp corner is shorter than the width of the stroke.
@vectoradmin Oh, okey, take your time with the fixes, at least you have implemented the cusp feature, Affinity is still not being able to at least include that feature
Thank you for you hard work!
This has been improved in build 146
