Can't see entirety of Main Toolbox
MacBook Pro, 15" Retina, OS 10.14.6
The Main Toolbox is taller than the screen, and there doesn't seem to be any way to scroll it to make the lower tools visible. I tried the two-column mode, but that just seems to make more tools visible, not make the Toolbox shorter.
Hi,
Select application "Preferences" go to the "Panels" section (in the "Section:" box), edit the "Tool Box Lines:" field to 2, then confirm with "Ok".
The "Toolbox Style" in the Panels menu loads a different toolbox, where more tools are available and it is used in even larger screens. You may also try the "Small Toolbox Icons", with a single column toolbox, but the difference is not that big.
Thanks! That did it!
Is there somewhere an explanation of what >all< the Preferences choices mean? There's a lot to get your head around...
The Preferences choices are described in: https://www.vectorstyler.com/documentation/customize/preferences/
Also, if you hover the mouse over a field in the Preferences view, then a tooltip is shown with an explanation.
Thank you!
Just a minor niggle: in the Preferences documentation cited above, in the Canvas Settings area, the initial "Shape," shown below, should be "Shade."
Artboard Shape - Select the shade color of artboards.
Artboard Shape Offset - Select the offset of the artboard shade.
Artboard Shape Opacity - Select the opacity of the artboard shade.
Thanks! fixed it.
