    Not only is it useful, I use it all the time because it is so easy to use, easy to remember is there and often I have the pointer next to it anyway thinking I have blank pages available and want to jump to them, but no, this is the last page - and then it is a no brainer to press the same next button to add the page or pages. It is a workflow smoother.
  • Adding noise to a colour in a simple way
    @ZATOPEK a couple things to consider when comparing noise effects : Affinity adds a white noise on a pixel basis (each pixel value seem independent of its neighbours), it is not a grain effect or 2D noise where neighboring pixels would have correlated values. document size in pixel will influence greatly the size of the noise "particles". A smaller document will have bigger noise particle size in relation to vector shape, than the same noise applied to the same shape on a higher resolution document Affinity rendering engine is very well optimized for fast rendering of multiple layers and uses dynamic image resampling based on display zoom. So, relative noise size will change as you zoom in and out. This can confuse you in thinking you have large noise grains at low zoom settings. But when you zoom in, you see the noise gets smaller and smaller same goes for exporting. If you export at low resolution, you will get large noise grains. If you export at higher resolution, you will get smaller noise grains. Noise grains are one pixel always a way to get a more accurate view in both AD and VS is to switch from vector to pixel view mode. You will avoid the display oversampling at high zoom settings. AD's noise in color chooser is smart and very easy to use, but it lacks configurability. On the other hand VS White Noise image effect is less immediate, but offers much more configurability (experiment with different noise types - random parameter, limit, amount, blend type ...) and you can get all sorts of variations. On SVG export, both AD and VS need to rasterize the noise into a clipping mask as noise is not a standard SVG attribute. [image: 1774688327207-scr-20260328-iyhh-resized.png]
    To make the idea clearer, I’ve put together a visual overview that highlights the key behaviors and interactions of the tool. This idea comes from observation rather than direct experience, so there might be some flaws in the logic, but I believe a similar behavior could still be worth considering. The idea was also influenced by VectorStyler’s strong snapping system it made me wonder whether a form of tangent locking could exist within a similar logic. [image: 1774530197045-vectorstyler-feature-idea....png]
  • Advanced Bezier Editing for Logo & Lettering Work
    @VectorStyler Intelligent Line to Curve Conversion I will add this to the backlog. Can you send me a few before / after examples for this? Here is a short GIF showing the behavior. It allows moving straight segments without creating curves, preventing accidental distortion. Curves are only introduced intentionally using Alt. This behavior is currently possible by selecting multiple nodes, but the goal here is to allow direct segment selection and manipulation with a single click. Especially when shapes overlap, selecting the correct nodes can be difficult. With this behavior, you can directly select the segment and make adjustments more easily. https://imgur.com/a/hfikSNx
  • Auto-frame
    @VectorStyler Well... VS is already a DTP, not much difference between it and DTPs out there. The only issue is that people is not using it as DTP so it need some polish on it. But it looks with powerfull possibilities.
  • Could "Dim Outside of Artboards" darken what is outside the artboard?
    @Boldline In the Colors tab there are the Dimming Color and Opacity options
    @Boldline said in Could locking a layer free up VS to only render and focus on active layers?: it will essentially tell VS to see that selection as an image and not try to render and re-render the nodes each time I work on other parts of the file? Yes. Is there a time I should leave it off or turn it off at a given point? It can be too slow if there are only a few vectors in the layer. It works better for large number of (unchanged) vectors, gradients or image effects Should I be adjusting anything with the "rendering thread"? Let that unchecked, so it will use the current number of CPU cores on the system
  • Alternative Ideas for gradient creation
    @EricP Thank you, because that's what gave me the idea to try it. Although I thought you'd know it and point it out. As I already wrote, it's quite misleading that the gradient object initially receives a solid color fill and then you have to create the gradient again with the new colors. As I wrote in my thread "Houston, I have a problem...", it's quite often the case that a feature one need is already build in. I always wonder how @vectorstyler knew before hand what I would need. But my suggestions about creating a gradient are still valid.
  • Batch export, export selected objects as individual SVG files
    @VectorStyler Thank you ! I figure it out also myself a bit, via the Manual. Was a bit irritating to find the Object Export Panel under Menu > Editing. But i can live with that. If i have further Questions, i may come back. Anyway its really nice and handy to have this feature. Thanks again.
  • Add a distance / measurement tool for arbitrary points and objects
    @VectorStyler Select the 'measure' tool from the toolbox. Click on the first control point. Click on the second. Bring up the translate dialog-it'll have the measurement between these two points loaded and ready to go. You can have another object selected and it'll translate that object when you hit 'ok'.
  • Connect Tool
    @861475_VctSt said in Connect Tool: When lines intersect, the detour method is crucial. That can make it more complicated.
  • could we set VS to recognize it even if it's clipped inside a group?
    @VectorStyler yes only for expansion. thank you!
  • Create New Layer Icon Too Similar to Create New Sublayer" Icon
    No reason not to build directly on the current VS "regime" that is comparable to the interface in Illustrator: [image: 1770683932446-26b64e2d-ecfe-4d2c-8bc5-69a9942e641f-image.png] Here, Illustrator wins on visual simplicty, though. I can only imagine the VS icons can be simplyfied a bit too. A plus sign in a single square icon is all we need. Sublayer? I dunno, just as gymspiration: [image: 1770684790138-5771e636-20d5-4f4e-aa7f-3a1d123b3800-image.png] [image: 1770685047298-30c9259d-a7f3-4998-a7af-99f19d585a66-image.png] [image: 1770685170190-6678b144-4202-4eee-a19f-d737131f871c-image.png] BTW icon tooltip says new sublayer, right click menu create layer inside.
  • fractal glass effects option?
    @Boldline This is a pixel based effect. It could be added later to image effects (no plans for now). Maybe a similar effect can be found in the SVG effects of Inkscape, and those can be imported to VS
  • Value slider for pattern size
    @VectorStyler thank you
  • 3-Point Rectangle and the 3-Point Circle tools suggested enhancements
    @William-Kansepa I added this to the backlog
  • macOS shortcuts / “Close View” placement
    @Ingolf I checked this in other apps (AI, AD), and the "Close" command is the same as the Close View in VectorStyler, it closes a single view of a multiple view document
    @Boldline @Subpath I added this sto the backlog opf features for 1.4
  • XLS for features and ideas - Megathread
    191
    570k Views
    DanielD
    @VectorStyler: I tried this too. Didn't note down how it affected performance. Will report back. Thanks!
