  • Detail optimizations for version 1.4
    @VectorStyler https://youtu.be/ED0mRNJZFMQ While drawing anchor points or dragging handles with the Pen Tool, you can hold Ctrl to move the current anchor point as long as the mouse button is not released. This feature needs to be added.
  • Split Stop Gradients
    DanielD
    @VectorStyler: No. It is not. It simply the same colour stop split into two. At the level of code, it is colour stop +/-, left and right. I can ask the dev more. It works like Blend-if Stop in PS. Except, it is a real colour stop. And the point of export, it is converted to a true colour stop.
  • New Feature Requests
    @VectorStyler https://docs.astutegraphics.com/vectorscribe/extend-path-tool/extension-modes [image: 1795313215359-073e84bd-0d37-4076-bfc9-6fefa21d393c-image.png] [image: 1795312980032-27dcc5dc-6703-4874-b759-499df70232af-c6e469a294ed99ef764ae1d6698d3c58.png] This tool needs these three extended modes to be selectable to suit different workflows. The fourth one marked with the red arrow can be omitted.
  • Detail Optimizations for Version 1.3
    61
    @VectorStyler https://youtu.be/acvbZgKlfno https://www.youtube.com/shorts/Os1mnFEH5aM The current centerline effect still isn't good enough. You can refer to the effect in this video. I set up an English interface so you can see it more intuitively. I hope it can be improved later. Thank you.[image: 1795165357146-create-centerline-resized.png]
  • Autofill Crash Report Username and email
    @Boldline I will find a solution for this
  • Previewing Image Effects
    @Subpath I added this to the backlog
  • Batch Export Layers Using Canvas or Artboard Bounds
    Why not have the ability to export layers with the document dimensions? So each layer would be treated like an artboard.
  • Reveal and highlight docked panels from the Window menu
    @Boldline Send me your workspace and settings files. I could not replicate this issue here (panels are revealed when selected from the Window menu).
  • Make Locked Objects Selectable Only When Needed
    @VectorStyler I’d like this in both the Transform and Node tools. I run into the same issue with the Node tool when I’m trying to select a vector shape on top of a locked shape or raster image. I’d like to switch between Ignore Locked Objects and Allow Locked Object Selection from the contextual menu bar. Could the contextual menu bar also offer Add to Locked Objects? It’s similar to my earlier request for an Add to Selection option like Affinity 3 offers. Here I’d be adding to the set of locked objects. When artwork overlaps, I sometimes need several passes to lock everything I want. If a later selection includes both a locked object and an unlocked one, the current Lock/Unlock shortcut can unlock the first object. With Add to Locked Objects, I’d choose the option from the contextual menu bar and both objects would end up locked. The existing Lock/Unlock shortcut already works well for everyday use. I’d like these options to appear in the contextual menu bar when relevant, which saves permanent toolbar space and gives me one less shortcut to remember. Addendum: One more option for selecting locked objects would be a modifier I can hold while clicking or drag-selecting in either the Transform or Node tool. That would let me include locked objects when I need to. Once I release the modifier, normal selection would skip them again. The objects would stay locked until I explicitly unlock them.
    @VectorStyler The Repeater has the exact same issue as well. Please see the difference between version 1.2.090 and 1.3.033 [image: 1794320332583-clipped-halftone-1.2.090.jpg] [image: 1794320318597-clipped-halftone-1.3.033.jpg] Clipped Halftone.vstyler It would be great if Vector Halftone could have an Expand feature, just like the one in Repeater.
  • New gradient features
    @monsterfox Custom gradient shapes can be defined, but they are by default linked to the object shape.
  • Scale nodes and handles with zoom.
    DanielD
    @VectorStyler: Not all the way through to 1 million zoom levels. That's ridiculous and useless. But at the very least up to 200 to 300%.
  • Add Steps option to Compound Tool like with Drop Shadow Tool
    @monsterfox yes that was what I was intending. I was referring to the fact that there were control settings on the drop shadow, not the actual drop shadow features themselves. Sorry for the confusion!
  • Bezigon Tool
    87
    5 Votes
    DanielD
    @VectorStyler [image: 1793456990737-6646579a-3bde-4765-a8c4-dce42d78d891-image.png] I found an extremely simply alternative to tangent nodes. This avoids even the need for locked nodes. You simply snap to chord. That's it. But locking would still be extremely useful.
  • Optional Shape Diagnostics Before and After Boolean Operations
    @Boldline I will try to add this as soon as possible.
    DanielD
    Another win for Czechia. Can't believe this is a single guy's academic project. Just like Photopea! And what a total fucking shame! [image: 1793312549047-a0bdc437-11c8-4426-a8a1-f09ab1e95e5b-image.png]
  • Optional “Organize by Artboard” View in the Layers Panel
    DanielD
    @VectorStyler: This should be a toggle. It should not be up to the user every single time to ensure that the layers are on the right artboard. I work on multi artboard set up in Affinity all the time, and it is infuriating how easily you can place the layer in the wrong artboard. The solution is simple: A simple toggle at the document set up. "Artboard is Layer". Done.
  • Improving Text in VS: A series of suggestions
    @Daniel said in Improving Text in VS: A series of suggestions: Auto create new pages, auto-fit to container and shrink text on overflow: This might be added at some point after 1.4 Match Size: I click on one text box and then click on another, hit the button: Match Size. Now both text boxes match in size. You should be able to match width alone, height alone or both. Super useful. This exists in the Alignment panel (must be enabled from the panel menu) Dynamic text layer, text line, text box and text columns: Dynamic text layer already in VS. You click and start typing. The text goes on forever. But you can't wrap line. You should be able to. Text line - Already exists, but is miscategorised. Text on Path Tool. Why? Because it is a sub class of Dynamic Text layer. Instead of clicking and typing, you draw a line and type. No need for a separate tool. And yes, you should be able to wrap line here too. Is this the Text Frame? If so this exists, just drag a box with the text tool and you get a text frame. Can also flow into any shape. Embedding Graphics: Embedding graphics within text boxes should be a simple matter of either dragging a shape or image into the text frame in layer panel or pasting the object into the text box from the clipboard. Then there are the embedded graphics options. This can be added in the future. A basic version where graphics or shapes can be used a symbols in text already exists. Repelling and anchoring: Repelling and anchoring are the the true markers of a well-executed text function. Is this the Text Wrap? Named objects: You can give any object multiple names and then create links between texts and that object by linking text to that name. This is not the same as naming objects in layers. It is a separate category of names. You can also select objects based on their names. You can name anything. Colours, text, line patterns. Practically anything, and then select them as a group. This allows for impossibly quick selections. What does these links do? Does the text flow inside these objects? Table: Tables are quite difficult to get right. And get right Xara did. In Xara you can copy/paste any CSV file, and then covert it to a table with a single click. I can show you this later. This does not exist in VS. Equally, you can even flow tables across pages if you embed them in text boxes. This could be added further down the road. Matching styles: Say you have a piece of text in word and you want to bring it in to VS. And you have named styles in VS. When you bring it, you have the option of preserving the brought in style, or matching the style to your names. This is very intelligent and works better than in word. In MS Word, copy and pasting without preserving style means you have orphaned text with no style applied. But Xara creates a style for you. And that means, you can select and restyle it! Or even better, just match style when copy it in the first place. Depends on the format of pasting (is it RTF?) Word/PPT support - Xara fully supports Word and PPT export and import. Equally, it can import an entire webpage from online and preserve both text and image hierarchy perfectly. Super useful when you are prototyping. This is probably the least likely to have (or just further down the road). Per layer guide and per layer ruler setting: You can make guides only for specific layers. And you can have text ruler for each layer. Ruler settings can be copied and pasted along with all the text attributes. This is actually from PL. Still super useful. Is this active when objects in other layers are moved? Replacing font with one click: Let's say you have a text box with zero named styles. Mixed fonts and sizes. No problem. Click the layer and select a different font. Now you'll have a dialogue box that will let you choose which font you want to replace. A bit more complicated, but this should exist in VS with Find/Replace
  • Compressible Curvers
    @monsterfox said in Compressible Curvers: is there a suitable tool to revert this operation? Not yet.
  • Curve Comb to monitor curvature
    @Daniel I agree with you. I actually requested something similar here a few months ago, and this kind of simple, straightforward implementation is exactly what I had in mind.
