  • Normalize Child Object Opacity to 100% (Group Cleanup Command)
    @Boldline said in Normalize Child Object Opacity to 100% (Group Cleanup Command): However, in production workflows it is common for groups to contain child objects with varied reduced opacity values while the group itself remains at 100%. Send me an example file with this case.
  • Group and Hide fonts in the new font panel
    @Boldline The font manager can be used to organize fonts into groups, but that will not help in the Installed Fonts group. I will think about some new feature on how to organize dynamic font collections (like Installed Fonts) into some sort of folder structure. But this is for later.
  • Texture element generator for halftone
    @Boldline [image: 1765857150315-noise-resized.jpg]
  • A suggestion for the Font Panel
    Great. Im reading my post, i believe i dont expressed right. I believe that the Last used font must be at top, below the font used previously, and so on. Sorry my english is harsh.
  • Up&Down arrows behaviour
    @marce said in Up&Down arrows behaviour: instead of it you popup a slider. So, you need to move your mouse again and slide to the desired value Personally, I like to scroll values up or down by clicking on the field name and moving the mouse up or down. Very efficient. It avoids having to move your mouse to fetch the slider ball. Works on most fields (except ones with 2 input fields)
  • Text Wrap Panel and Text Wrap Options
    @marce I added this to the backlog
  • Add sub-categories to the repeater presets menu area?
    @Boldline said in Add sub-categories to the repeater presets menu area?: When I go up a level and into the presets folder, I see one repeater preset listed. I don't see the default repeater presets that come with VS or the several custom presets I already created. That file contains all the current repeater presets. The default presets file is in the VectorStyler bundle (similar location), but it was copied to this file. When I look in the Window>Presets Flyout menu, I see dedicated options for brush presets, document presets, an option to open a brush preset file. I was confused why the brush presets options are listed but not the other presets, but I assume that's because users are most commonly importing brush presets? Brush presets have a separate menu command because it is quite common to use these and there are typically many of them. Other presets could have a separate panel, but then it gets too crowded with menu commands. You can drag out a section from the Presets panel into a separate panel. When I go to the presets panel, repeater brushes are not listed at all. You mentioned it might be a bug, but I have an old windows laptop I had yet to upgrade to VS1.3, so it was still using VS1.2. On that laptop, the same presets panel also lacks a repeater preset folder I will fix this
    @marce No such option at this time.
    @VectorStyler No problem, it was just a thought and I also suspected there was a reason for it.
  • Transform Object lacking preview option
    @William-Kansepa I will try to add this if possible.
  • Shape Builder : Option to use color of first shape
    @EricP I added this to the backlog
  • Repeater : snap to grid
    @VectorStyler thank you
  • image blending
    @monsterfox Not supported, there are no image blending features in VS and no plans to add these. It would be more suitable for a photo editing app.
  • Quick radial tool
    Just played a little around with this. Here a video how you can easily change the shape that is in the repeater [image: 1764974063770-artboard-6-resized.jpg]
    1k Views
    Playing devil's advocate a little here - what is the next logical step by the user after they click "styles>repeater>create repeater" ? You see the repeater activate, but you are unable to edit the repeater in any way and the odds are, the repeater result would need some adjustments
  • Smooth tool
    @Daniel I love the ideas you've shared for the "simplify path" tool. I may end up using it a lot more as those ideas get added as @VectorStyler sees fit. I appreciate that VS has options for designers who need precise and exact edits to their curved paths and another option for those who are going for what looks good by sight for their art and are not needing something technical
  • Mirror Group Tool
    @FastVector I have this in the backlog already.
  • The ability to create bevel and extrude effects in VS
    @Ancientruines said in The ability to create bevel and extrude effects in VS: What is the status of this feature in VS? Not supported yet.
  • Bezigon Tool
    5 Votes
    DanielD
    My vociferous campaigning to get this tool into more apps has paid off in one more place: PhotoLine now has Bezigon as a subfunction of the curve creation tool!
  • middle tilt
    @VectorStyler https://youtu.be/wCb5HcgfmEA?si=QiaFkjTKRxOoLgrb A shoe has a medial side and a lateral side. If it can support middle tilting, I can create graphics for both the medial and lateral sides simultaneously, instead of making one half first and then mirroring it to the other side. This will greatly improve my efficiency. I've found several similar cases for your reference.0_1764686719634_555.vstyler
