  • Boolean Mode
    DanielD
    @Subpath: Just saw the full Moho official video. That is wild. I remember a while ago, I posted a project similar to that was going to open source. I can't remember the name. I will find it - I definitely threw in the mix. I want to know what happened to it.
  • 5 Votes
    DanielD
    @Subpath: Oh I am indeed anti-royal family myself. Buncha scrounging pack of vultures who live off the back of hardworking British people. Feck em.
    @Boldline Repeater (and halftone) copy / paste should be in the Style dropdown menu of the panel.
  • 8 Votes
    @Daniel This is not intended for use with fonts. It works "ok" once you have expand strokes and wish to obtain a path again.
  • HarfBuzz - the gold standard of text engine. Thoughts??
    @Daniel "Already build in" seems to be a running gag with Vectorstyler See this Post of mine https://www.vectorstyler.com/forum/topic/5677/houston-i-have-a-problem-vectorstyler-solution-is-already-build-in
  • Adjust Stroke Width of Multiple Selected Nodes Simultaneously
    @Boldline I added this to the features backlog
  • Add Real Time info button to Stroke Width Tool
  • custom panels
    @monsterfox I added this to the features backlog
  • Add Unlock to the Right-Click Menu for Locked Objects
    @vectorstyler Thank you for adding this so quickly! It's a great addition to the workflow
  • Group Isolation as a Full Editing Context
    @Boldline Those changes should all work in Group Isolation mode: with double click on a group, only objects inside the group are available. Is the issue with the dimming of objects outside the group?
    @VectorStyler Could we revisit this request? A visible indicator beside the active Settings preset would make it clear when the current settings differ from the saved preset file. For example, after loading a custom preset and changing a setting, its name could display an asterisk, such as β€œMy Settings *”. Saving those changes back to the preset should clear the indicator. It could also be like VS working file that has been edited but not saved recently [image: 1790720868789-fd023bd8-1ad3-49c6-b7a8-ca6e774b7d05-cleanshot-2026-09-29-at-6.27.26-pm.png] This would remove the guesswork about whether later adjustments have been saved, especially before switching to another preset or restoring the defaults. If I switch presets while there are unsaved changes, an optional prompt could offer three choices: update the existing preset, save as a new preset, or discard the changes and continue switching. This would work much like the unsaved changes warning for a document.
    Corel draw have such a feature But it doesnt have the awesome split Feature Here a Video how it works
  • Repeater, be able to link values together
    @VectorStyler Yes,That makes more sense. If identical parameters are required, fill in the same values in both fields and then lock the ratio for easier operation.
  • Repeater: Improvements and Feature Requests
    @Li-Xiao I will try to add these.
  • More Sensitive Path Simplifier and Dedicated Smooth Mode
    @Boldline I added this to the features backlog, I will try to improve these smoothing operations in the future
    @Boldline Added to the feature backlog, but maybe after 1.4
    @VectorStyler After experimenting a bit with the region option for color sampling, I have to say that it doesn't really convince me at the moment. The results simply aren't that predictable. I find using "Along Path" in conjunction with a clipping path to be more predictableβ€” even if you might have to cut out the desired part later on. Here a pic [image: 1789376180210-clipped-along-path-small-part.png] . . . As for color sampling, as it is by now i find "Paragraphic" more useful and easier to work with. It would be great to see improvements in this area in future versions of Vectorstyler, as this method offers interesting possibilities for coloring vector object designs and serves as a nice way to create compelling color palettes.
  • Feature Request: Customizable Radial Menu
    @Boldline I posted a request for something like this a while back. I looked for alternatives on macOS and found a few. While they aren't dedicated solutions, they offer quite extensive capabilities. The first one is Kandoβ€”a free appβ€”and the second is Cirmenu, available on the App Store. There are quite a few apps of this type, but many rely on a subscription model, which isn't really my thing. Check them out; perhaps one of them will meet your expectations.
  • Feature Request: Zero-gap Divide using no-fill / no-stroke cutter
    @Li-Xiao I will try to add this
  • Additional Interactive Controls and Options for the Arc Tool
    @Boldline I will add this to the features backlog
