  • Set and Save customized view locations in the navigator panel
    @Subpath cool! Illustrator might also have it but I wouldn't know since I stopped buying it at Cs6. I like the way Affinity tucks the saved viewpoints away and you can click to get a dropdown of others
  • Copy-paste when the...
    @Pat said in Copy-paste when the...: It would also be interesting to be able to CtrlC-CtrlV any object selected through the Layer panel In the Layers panel menu -> Panel Options (last item) enable the Object Pasteboard option. By default, the layers panel ctrl+c/ctrl+v is to copy / paste the object name (think of batch renaming from a text editor). But object copy/paste can also be enabled.
  • Alternative method to align objects
    @Boldline as i came from Coreldraw, which also has options for aligning nodes but I can say that VS is far more superior here can only recommend to experiment with it
  • Paragraph styles panel
    @VectorStyler I've just tried out text styles again in VS and so far it's difficult to use them for a page layout. In a DP app, the style of a paragraph includes, of course, the specifications of the paragraph but also the font and its characteristics (light, bold, regular, size, etc.) In VS, unfortunately, it seems that the font itself is considered to be an override of the paragraph style. This should not be the case. Only a defined character style should be considered an override.
  • Adobe's Save for Web Feature
    @gotanidea Added this to the backlog.
  • Add swap option to VS top horizontal tool bar?
    @b77 I occasionally use shift-x for this but it is a little different when I am using the stylus because the fill and stroke indicators at the top of the screen are not far from where I'm usually working. So when using the stylus it can be easy to pop up and click there. From what I see, they don't really serve a great purpose up there right now as is - since you can only adjust one at a time. To me, adding the switcher there would add value
  • Faster option for scaling brushes and eraser/path brush tool
    @VectorStyler said in Could the escape key be an alternative way to close out isolation mode?: @Boldline I added this to the backlog. Have to make sure that it does not conflict with some other key. There is also a new full screen mode in 1.2 (no menu, or panels) which uses escape to exit. Great! This will be a very useful feature, especially on smaller screens. Lots of room to complete a task.
  • Join Nearest Nodes
  • Second Modifier Key
    @William-Kansepa Actually, the problem is not the Proportional Object Scaling. But the inability to use Alt key as the modifier key of the Centered Adjustment option, because of the reason the Admin mentioned above
  • Paragraph panel: mouse wheel and values...
  • Button for Select > Options > Allow Locked Objects
    @Boldline said in Button for Select > Options > Allow Locked Objects: all of the folders on the left side are named "Folder". Yes, these were not named as the name is not used anywhere else in the UI. I will add some default names for these.
  • Brush Format Options
    I see! So cool! Thanx [image: 1686404457650-e24ca035-8f3a-4aeb-81b6-b248c4c9d056-image-resized.png]
  • Streamlined VS Workspace
  • Ergonomics
    R
    EDIT: actually in full screen mode (and tablet mode for the future), these kind of things might help. I agree. "Would this be the right click menu?" There will be no need for context menu, toolbar icons will be what is in context, remaining toolbar items will be hidden. Toolbar is activated with context tool icons, trigger by what the user does ( trigger by selection e.g.) I hope I am clear, pardon me it is just a small idea to have more focus on the canvas and tools are in the background, and called in the UI when needed. Makes sense?
  • Gap Tool ideas
    @b77 said in Gap Tool ideas: Preferences > Editing Options 2 > Show Editor Popups displays the moving distance. So here is an example of where the popups being active would interfere in my work. I would turn this one off specifically and leave others on
  • Possible confusion finding preferences settings
    @Igull it is hardly original - it has been in use for several years now: https://www.google.com/search?q=ipadification
  • Tying the font size to the transform scaling of live text
    @VectorStyler Yes, the "direct shape transformation" is checked on. I also restarted VS fresh and had the same issue. [image: 1686160139731-dd91de10-a9c9-4d95-b4c2-326b7e7410d0-bld-2023-06-07-at-13.39.23-resized.png]
