Could objects saved in clipboard paste on top of offset path result by default?
I think this topic was brought up before, my apologies if it was... but when I have something saved to the clipboard and then select another object to apply an offset path to, after committing to the offset path result, if I press command-v to paste what was on the clipboard, it pastes below the offset path result. I think it would be more effective to have have it paste overtop...
Also, there are many times the lowered opacity of the offset path used to help with the preview does not automatically bump back up to 100% when committing to the offset path settings.
@Boldline I think it should paste above. I added this to the backlog.
