  • How do I copy an Image Effect or style from doc 1 to doc 2?
    @Raaskot said in How do I copy an Image Effect or style from doc 1 to doc 2?: A minor request for new users: Copy/Paste option included in pop up would be a help though ... I will add this for 1.3
    @VectorStyler Awesome! I'm glad you might have a solution for this. I twill greatly help the use of the path brush
  • How to convert enveloped effects to Curves?
    @VectorStyler Got it. Makes sense
  • Is it possible to suppress a Shape Effect via a Shape/Mask Role ?
    @Subpath I used displacement effect for this. I will find some time in the next few days to record it. [image: 1754232000916-vs-resized.png] [image: 1754232009466-a-resized.png]
  • Line Width tool options?
    @monsterfox said in Line Width tool options?: Could this display function be added? I added this to the backlog
  • Can't save
    @VectorStyler Understood. I will back up that folder regularly. The following data xxx.settings xxx.vstool xxx.vswork may be modified by updates, so even if you back it up, there is no guarantee that it will be 100% inherited.
  • Where to disable the Selection Frame which follows the Shape form ?
    @VectorStyler Thank you
  • How to make VS remember last used brush/pen tool colors, widths ...
    @VectorStyler thank you for having included that on last release. This saves me a lot of clicks
  • custom toolbar
    @VectorStyler [image: 1752937370447-mmexport1752937085027-resized.png] [image: 1752937370110-mmexport1752937080362-resized.png] There are still many functions that don't seem to be in the list of custom toolbars. Maybe the factor you considered is that these are used less frequently. However, the functions of horizontal and vertical average distribution are used quite often, and it's hoped that they can be added to the list.
  • Prevent distorting round corners – how?
    @VectorStyler Very good, thanks! Yet I think as an user this UI issue is utterly tricky: I'd never guessed to open the (1) Appearance Panel and (2) select Fill-item and then (3) pull the menu to click the (4) Transform Content option without your help I'd expected this in the RM-popup on object instead. Then I could check and compare for object issues. Perhaps with an other name than just "Transform Content" since this also includes the frame? [image: 1752301620606-e1edc3de-27ce-4686-a1b4-65e7f2c6b050-image-resized.png]
  • Syncronization don't appear with other fonts of the same style
    @Raaskot Those values (red marker) are part of the Paragraph Styles.
  • Update defined character and paragraph styles, how?
    @VectorStyler https://www.vectorstyler.com/forum/topic/5269/move-character-and-paragraph-style-panels-to-text-menu
  • Bounding box around text / objects
    Thanks guys! Next time, instead of asking if a feature is available, I will immediately ask where to look for it.
  • Copy-Paste between applications - maintain object size
    @EricP I opened a bug on this. Groups / layers should be copied correctly.
  • Content Crop tool - How does it work?
    @Kumr Must be used on images or linked PDF objects
  • New Document Setup
    @B-Vs-V When using the select folder, the options are hidden by design. There is an error here with the name for the "preset" list.
  • Commas vs dots in numerics. How?
    @VectorStyler Same here, cool, thanks
  • having problems printing to manual feed tray
    O
    @VectorStyler thank you for looking into it. I did get around it by printing to file and then opening that in Preview and printing from there. Preview prints it just fine. Hopefully one of us will be able to figure out what's going on here! In the meantime, I'm loving VectorStyler. It has a lot of the features I've been missing from my old Illustrator + Astute Graphics workflow. Thanks for producing such a feature-rich drawing program!
  • How should position adjustment in the Repeater work ?
    @Li-Xiao Wow, pretty pretty cool. I need still a few more tries to figure out how "Adjust Position" works. It's still unpredictable for me at the moment. By the way, since I used to work as a screen printer for a few years, I'm familiar with moiré patterns that can occur with halftone printing or overlapping Screen folie. Always found them interesting. I had a few ideas after watching your video. One was that if you use red and green dots and some of the old 3D red-green glasses, you might be able to see a 3D effect. But I've also seen many other uses. Again, thank you very much for your help and the insights you've given me and I'm sure other users will be grateful to you for that too.
