    Bounding box around text / objects
    8 Posts 5 Posters 4.1k Views 5 Watching
    • encartE Offline
      encart
      Is this achievable in VS? I've been trying different methods since yesterday but I can't solve this problem. Often in my projects I have a large list of words which I then send job to my plotter. Adding a box like this makes it easier for me to process later. For a few objects it can quickly be done manually, but not when there are, for example, 200 objects.
      The second option is whether it is possible to create such a box for regular objects. I select the objects, set the offset and a box is generated around each object.
      https://www.youtube.com/shorts/PjylYU9-BkM
      S L VectorStylerV 3 Replies Last reply Reply Quote 1
        Subpath @encart
        @encart
        There is a Data Source Panel in > Menu > Windows > Styles > Data Sources
        which may be helpful. I never work with it, so @VectorStyler should be
        more competend with it.
        Here a Link to Online Help Section
        https://www.vectorstyler.com/documentation/symbols/datasources/
        Also searching the Forum with "Data" may bring some information.
        • L Online
          Li Xiao @encart
          @encart
          Adding bounding boxes around text or objects is very simple and convenient, and I have recorded a video for reference.
          Text
          https://youtu.be/FWDcCjALFyE
          Objects
          https://youtu.be/TwqixG5CY_8
          @Subpath
          I also recorded variable text for reference.
          https://youtu.be/IJwPpPMELhs
          S 1 Reply Last reply Reply Quote 4
            Subpath @Li Xiao
            @Li-Xiao
            Thanks for the video about using text variables and also
            for the other two videos. It's always interesting to me to see
            how others approach a problem.
            The curious thing about text variables in Repeater is that I
            once suggested it for the Repeater. ☺
            But as I said in my suggestion, I didn't really need it myself.
            However, I thought it would be a good repeater addition.
            Here the LInk
            https://www.vectorstyler.com/forum/topic/1825/idea-to-add-autotext-numbering-to-repeater
            L 1 Reply Last reply Reply Quote 3
            • L Online
              Li Xiao @Subpath
              @Subpath
              Here the LInk
              Great Idea. 👍
              I often use variable data. Currently, there are some issues and improvements needed with using data sources in the repeater.
                VectorStyler @encart
                @encart No such feature in VS, but can be simulated with "measurement" variables
                • E Offline
                  EricP
                  @Li-Xiao thank you for these videos. I learn so much from each of them
                  • encartE Offline
                    encart
                    Thanks guys! Next time, instead of asking if a feature is available, I will immediately ask where to look for it.
