• Is VectorStyler Apple Silicon (M1) ready?
    badcatB
    @vectoradmin I submitted.
  • Pen Tool _ Restart Curve at Node (See Links for Examples)
    @Jae There are additional improvements for the pen / node tool in the new build 201
  • Brush and Pencil tool issues
    @Boldline Using solid stroke as a default brush should work in the new build 201
  • Reset Center
    badcatB
    @vectoradmin Yes - the original shape was an all vector SVG.
  • Opening VS shifts panels to left
    @vectoradmin just installed it and works perfectly now
  • Intersecting Selections Option - seems to remain enabled when unchecked
    @Jae The intersection mode problem is fixed in build 198.
    The new build (198) fixes these issues on Windows: fixed: single key shortcuts were broken. fixed: when in full screen mode, first covered the task bar then the top area was moved out of the screen (hiding the menu bar). modifiers for pencil, pen and node editor tools are fixed. The documentation update is still in progress
  • Are there plans to release VectorStyler for the WINDOWS platform?
    25k Views
    @Boldline The WIndows installer is signed now with EV code certificate. This should have a better user experience in installing
  • Tried the Windows install...
    @curvy1 There is only Windows 10 version planned for now.
  • Missing Contextual Menu
    thanks @badcat - that solved it. I'm not sure how I turned it off but it wasn't intentional and then I was thinking it was a preference option I needed to use. thanks for the help!
  • Simplify undos
    Much better, thanks!
  • Snapping and/or smart guides assistence
    It seems to be working now! Thanks!
  • Color picking?
    @b77 That's a great tip, thanks a lot!
  • Layer lock options: lock position only
    Thanks for your reply!
  • Personal compliments to the developers!
    I also am very grateful for Vectorstyler and the dev team putting this together. I am currently clinging to Adobe CS6 as I remain hopeful for a replacement app more powerful to replace it. I am completely opposed to subscriptions and much prefer the alternative solutions many software companies are using. I like the system Serif uses and also the proposed one VS will offer. I want to support developers and pay for the software that allows me to do work that pays my own bills - I just don't want a draconian overpriced subscription service as my only option. I was/am a fan of Affinity and have used it wherever possible over Illustrator but always end up back in Illustrator to finish off designs I started in Affinity on ipad or desktop. Unfortunately, Affinity is on a slow improvement track and vital tools I use daily for work are long promised and slowly delivered. I love the responsiveness of the VS dev team and their willingness to listen to our ideas and consider them and then to even implement them in short time frames. It makes me feel proud to see input I've given as a professional vector artist, show up in an app that will benefit so many. I'm sure many of us feel that way. I'm also so impressed with the sheer number of options and abilities for what can be accomplished in a vector app. VS blows away Illustrator, Affinity, Corel, etc... It becomes more user friendly and ready for RC all the time. Thank you for dedicating yourselves to making this a great solution for those of us stranded by Adobe and Affinity in some ways and other apps.
  • Way to turn of layer preview when selecting?
    You changed this so quickly! Very impressive, thanks!
  • Speed/responsiveness?
    You could try in the Preferences -> Performance, if Metal is visible, and how it performs. In Sierra, metal compute was not yet complete, so probably there should be OpenCL. For display mode, try if Metal works, if not OpenGL. For your config, probably Metal for Display Mode and OpenCL for compute. Software is a last resort. For compute it can be acceptable if you have cores, but for display it can be slow.
  • Warp Use Questions
    The text on path view has been rearranged and a bend mode was added to the Transform modes. This also works with the interactive text on path tool to adjust the text along the path. [image: 1602333182393-icon2.png]
  • How to create clipping groups?
    For the drag ad drop in the Layers panel: drag the group object (or single object) over the label (name) of the target object in the panel. There are two types of indicators that may show while dragging the object over another: placing before or after the object is shown with a narrow blue line between two objects (in the panel). placing inside the object is shown with a wide blue highlight over the target object.
  • Effects preview checkbox
    The state of the preview button is kept as follows: shape effects each keep a common state for all shape effect types. image effects each keep a common state for all image effect types. individual color effects keep a separate state (this may be a problem). I added to the bug list to have a common state for Color Effects (first section of the Effect menu). Will also reconsider the default state (to be on).
