• strange issue like there’s two brushed applied to same stroke
    @Raaskot said in strange issue like there’s two brushed applied to same stroke: I understand, yet the Stroke Width Tool only seems to apply to one of them Should be the one selected in the Appearance panel. I will also test this, could be a bug here.
  • Fit Text Frame command -- how?
    @VectorStyler Cool, thanks [image: 1785928280204-708ac8b7-078e-42ec-a81c-6f893d56fb50-image.png]
    @Subpath I will try to fix this
  • Paste in Place
    @VectorStyler fiame text.zip Not all of these cases will work (depends on the shape text), send me an example. See attached video.
  • Vectorstyler on Linux?
    krasovskyK
    @VectorStyler nah, it's mostly dead. All modern desktop environments are focused on first-class Wayland support. GNOME already dropped X11 support completely, KDE will drop it by the end of the year. Many new popular tiling managers like Hyprland or Sway are Wayland-native from the start. Older ones like Cinnamon and XFCE are actively working on Wayland support, but they are not as popular as they were in the past. Modern Ubuntu by default ships just its own flavor of GNOME, if you missed that part. Overall, a major part of Linux users still split mainly between GNOME and KDE. KDE recently has gained more popularity since SteamOS adopted it, and overall development has sped up. Also, there is a big surge in so-called atomic or immutable distributions: those have a fixed system image that is immutable; you cannot install or uninstall system packages, remove your DE accidentally, or mess up the dependencies. The only things you can change are config files and your /home directory. The main source of apps for those distros (e.g., Fedora Silverblue/Kinoite, Bazzite, SteamOS, etc.) is Flatpak and Docker/Podman containers. Basically it is similar to how modern smartphones function. So, again, with Flatpak you would cover both immutable and basic distros. By default, the Flatpak platform is not installed on Ubuntu, because Canonical has its own similar technology called Snap and its own store called Snap Store, but it can be easily installed using one command, though it usually makes sense to upload to both Snap Store and Flathub. If resources are limited, Flathub is preferred, since Snap support outside the Ubuntu ecosystem is questionable. From a developer's perspective, the key difference between Flatpak and Snap is how applications are distributed. Flatpak allows anyone to host their own repository, while Flathub serves as the default public repository. Snap, on the other hand, relies on Canonical's Snap Store, and developers cannot host their own independent repositories.
  • Click Through Object Selection and Select Next
    @VectorStyler Great, thank you for your attention to this - as well! Select Previous - of course, noted.. In Macromedia FreeHand - my usual reference ad nauseam - the Click Through action is done by holding Ctrl + Right-click to cycle through the stack. Hold Shift as well to add or remove Click Through candidates to/from current selection. Hold Alt as well, to Deep Select into groups, composites, clipping groups, to add or remove Click Through candidates to/from current selection. BR/ Lars Herold
  • Is there a way to select small objects ?
    @VectorStyler ok thanks I see it now. I kept looking in the "select by shape" section by mistake
  • Text Stroke questions
    @VectorStyler oh fantastic, dragging the stroke underneath the fill in the Appeareance panel is exactly what I was looking for, this is perfect. Thanks for your quick responses in helping me figure this out!
  • When will VS be updated?
    @Boldline If there is a sufficient number of features implemented and tested, then October 2026
  • Just out of curiosity: Where is the color sample taken for a stroke?
    @VectorStyler I don't actually have a problem right now—perhaps I didn't explain it properly? Or maybe you misunderstood me for some reason. It’s just about a question: I was simply wondering at what point a stroke takes the color sample that then colors the stroke itself. Your answer regarding the center of the repeated object is fine enough for me. Thanks you.
  • Just a compliment to Vectorstyler
    5 Votes
  • Moving the bitmap after using it to color repeated objects in a repeater
    @li-xiao I’ve since figured out how it all works with closed paths/polygons in Paragraphic, and I’ve replaced the video in my earlier post with a new, up-to-date one. [image: 1783227572383-closed-polygon.png]
  • Creating a custom vector brush stroke
    @nrdesign, @devil-dinosaur Here is the Artistic brush Tut I promised—it’s finished and released. It took a few days longer than planned due to the heatwave here in Germany. The order of the day was mostly eating ice cream, drinking plenty of fluids, and sitting outside in the shade. Here the Link for the Tut https://www.vectorstyler.com/forum/topic/5850/some-basics-regarding-the-creation-and-use-of-artistic-brushes-as-well-as-a-fast-way-for-selecting-such-a-brush.
  • Content cropping tool
    @macos Send me the vstyler file containing that image (just before the cropping phase) to csraba at vectorstyler.com
  • VectorStyler won't load, stuck on initialization screen.
    Clippy notesC
    @mackotomi The only thing I can tell you is to update your computer's drivers and controllers. During the 1.3 update, my computer went crazy asking me for an update.
  • How do I keep VS spot colors when exporting to pdf?
    @VectorStyler Great! I'm very thanksful [image: 1782128472255-6b0938e7-2f01-467e-a157-c1ecd13747cc-image.png]
  • Distributing objects with a set distance doesn't work
    @Raaskot But it puzzles me what the Distribute section is for. It works quite erratic. Distribute should do an equal spacing between the selected margins (shown in the icon)
    @Boldline I will check the crash reports
  • Did incremental Backup options get moved?
    @Boldline The automatic backup options are in Settings -> Document Files
  • Image is changing position unintented when cropped
    @Raaskot Looks like the crop tool keeps the image centered. I will try to find a solution for this An other way to crop is to convert to curves and use the Node tool to edit the path of the image.
