    Clipboard
    4 Posts 3 Posters 2.7k Views 3 Watching
    • M Online
      monsterfox
      I use Freehand 9 quite often, but I can't paste the content from the clipboard into VS. Is it possible to quickly copy and paste between Freehand and VS? Thank you."
        VectorStyler @monsterfox
        @monsterfox Not sure what format Freehand uses to copy to clipboard.
        Can it be pasted to Inkscape for example?
        • M Online
          monsterfox @VectorStyler
          @VectorStyler It is possible to use the low - version AI format, but it cannot be pasted into Inkscape.
          • IngolfI Offline
            Ingolf
            FreeHand 9 apparently copies to the clipboard in the following formats:
            WMF, EMF, PICT (Mac only, DIB/Bitmap, FreeHand internal format
            You can reportedly copy in these formats via Copy Special:
            EPS, Adobe Illustrator 7/8, Bitmap, Text
            It seems the clipboard isn't well suited for use with Freehand and VectorStyler plus other modern tools, unfortunately.
            🍏 macOS Sequoia Apple Silicon
