      Image as fill in appearance
      2124
      @Jayanta-Das It is possible to make a tiling pattern from an image. And to use it as a fill (clipped into a shape) with no styling, just apply the image on the object using the Links panel.
      Locked layer: not totally locked ?
      5448
      @VectorStyler I've sent you the file.
      Is there a CJK vertical text function?
      • Huangzhi
      2715
      @Huangzhi More on this in the documentation: https://www.vectorstyler.com/documentation/text/cjk/ A text frame can be drawn as vertical (with the vertical text tools), or turned into vertical.
    • How do I regain the ability to move text on a path?
      4805
      @Boldline said in How do I regain the ability to move text on a path?: Is the expectation that someone would turn that preference on if they never had to adjust text on a path or flip it? I think the text on path tool should not select the anchor (shape) if this is on. But it could be a bug here.
      Duplicated text behave as locked object ?
      2911
      @VectorStyler File sent.
      Easily split a line into two differently configurable parts
      5147
      @VectorStyler Thanks, works perfectly well
    • Constrained Lines Question
      3041
      @VectorStyler said in Constrained Lines Question: @Igull Is the Smooth Nodes enabled in the context panel? Ahh - nailed it, thanks I was looking for something in the context panel, but that doesn't show until after you have started drawing - it might be better if the trigger for that happened when the pen is selected ? Maybe there's some other reason that I don't know about of course There is also no inferencing (to other points of the polygon) shown, I'm wondering if that is part of a snapping option ?? Neil
      How to move several objects in once in the layer panel from a layer to another?
      4700
      @VectorStyler and yes, I wanted to move objects from a layer to another one.
      Document in "mm" & text in "mm"
      3267
      @PatrickM said in Document in "mm" & text in "mm": Also, how can I adjust the frame to the text? No such option in VS, for now.
      Snapping: how to get this...
      3744
      Spanish Version
      • formulalatino
      3232
      @formulalatino I added this to the backlog. Will try to have translation by version 2.
    • editing the handles only of multiple nodes at same time - but not moving the nodes as well
      5536
      @Boldline said in editing the handles only of multiple nodes at same time - but not moving the nodes as well: pick certain preferences options and customize them in a dropdown folder Maybe in the future.
    • Deciding what part of separated path to keep and what to delete
      2364
      @Boldline When deleting a node, it will delete the segment before the node along the path direction.
    • How do I commit to changes made with warp tool and retain stroke attributes?
      3246
      @VectorStyler said in How do I commit to changes made with warp tool and retain stroke attributes?: To get back to editing nodes, you need to convert to curves (again). thank you - I found where I got stuck. If the node editing tool is selected and used to select the warped shape, then pressing "convert to curves" will not work - you need to switch to the transform tool and then try "convert to curves" to have success
      How could i switch off the " X " sign
      2971
      @VectorStyler thanks
    • Is there an option to not have the stroke width not change automatically when using the stroke width tool?
      4357
      @Boldline A possibly fast solution is to just select an object that has an uniform width stroke, then drawing with the Pen tool after that should revert to that width (or to 1 pt width if the previous object has no stroke).
    • Selection Confusion
      4536
      @VectorStyler No, the cursor is a small curve with circle on top plus a mini regular cursor LOL. I've tried a vid, but it's not capturing the above cursor change for some reason. The cursor changes from a regular cursor when hovering, to this other cursor when shift is depressed. Neil
    • Setting the unit of measurement in the export panel
      4318
    • Corner shape option does not show default curve - could we set the default curve?
      2576
      @Boldline Yes, at this phase it does not yet has any corners. First you must set a nonzero corner radius.
      Change key commands?
      • jfraze
      3671
      @jfraze When you don't find some feature or command you need, try the Search field under the Help menu (say, 'shortcuts'). If it's included, macOS will point it where it's located in the menus.
