    • does it make sense to have a zero width path brush stroke?
      2041
      does it make sense to have a zero width path brush stroke? No, not really, but there needs to be a lower limit.
      Why can't I permanently change the colour panel to "RGB sliders"?
      3932
      @VectorStyler I will finish a drawing and I'll send you the file. You can then test colour gradient changes with the "undo" function.
      Pattern brush.. Help
      3204
      @VectorStyler sent
      How to improve VS performance ?
      4121
      @Pat There is no reason for the slowdown, other than a possible bug with some effect or gradient type. If you send me that document I will try to replicate this.
      Editing a gradient colour
      7667
      @Jayanta-Das I will try to replicate this issue.
      Paste --> Paste in place -... : why in "Placing"?
      2339
      @VectorStyler Ok but why not create a submenu in "Paste" for all "Paste..." instead of having it in "Placing", it's just that I expect to find all the "Paste 'something' " in the same submenu of the "Paste" menu... not a big deal anyway.
      Testing Create adjustment layer: some effects apply to all objects (not only the selected one)
      6262
      I'm not sure, but I think the adjustment layers with effects is not a feature of other vector apps, but it does exist in Photoshop. It's awesome that we have adjustment layers in a vector graphics app.
      After Boolean Intersect, no more objects
      3403
      @VectorStyler In fact, "intersection" works if I merge the two letters first. I can't keep them separated in two distinct layers. Nice !
      Blending: how to get a specific path & not another ?
      4522
      @Pat Like your "VS" too very creative
    • Could/should the path stroke width be displayed when the path is selected with the node editing tool?
      1842
      @Boldline In the context panel? I think it could be displayed. EDIT: but then there are the other attributes, like color, etc.
      Curve/line & "break apart"
      1854
      Number of blended object limited to 256 ?
      1800
      @Pat Yes, it is an (internal) configuration value. Will be increased.
      Image as fill in appearance
      1889
      @Jayanta-Das It is possible to make a tiling pattern from an image. And to use it as a fill (clipped into a shape) with no styling, just apply the image on the object using the Links panel.
      Locked layer: not totally locked ?
      4716
      @VectorStyler I've sent you the file.
      Is there a CJK vertical text function?
      • Huangzhi
      2408
      @Huangzhi More on this in the documentation: https://www.vectorstyler.com/documentation/text/cjk/ A text frame can be drawn as vertical (with the vertical text tools), or turned into vertical.
    • How do I regain the ability to move text on a path?
      4114
      @Boldline said in How do I regain the ability to move text on a path?: Is the expectation that someone would turn that preference on if they never had to adjust text on a path or flip it? I think the text on path tool should not select the anchor (shape) if this is on. But it could be a bug here.
      Duplicated text behave as locked object ?
      2509
      @VectorStyler File sent.
      Easily split a line into two differently configurable parts
      4473
      @VectorStyler Thanks, works perfectly well
    • Constrained Lines Question
      2662
      @VectorStyler said in Constrained Lines Question: @Igull Is the Smooth Nodes enabled in the context panel? Ahh - nailed it, thanks I was looking for something in the context panel, but that doesn't show until after you have started drawing - it might be better if the trigger for that happened when the pen is selected ? Maybe there's some other reason that I don't know about of course There is also no inferencing (to other points of the polygon) shown, I'm wondering if that is part of a snapping option ?? Neil
      How to move several objects in once in the layer panel from a layer to another?
      4063
      @VectorStyler and yes, I wanted to move objects from a layer to another one.
