    • Does VS have a way to constrain every action to one specified angle?
      2873
      @b77 Thanks - I like the location of this option better than where illustrator has it. Rotating the canvas and keeping the created vectors and such in a normal view can be great for certain things. I wonder if an option to keep the canvas in normal view and rotate the material created might also be a good option to add eventually in some capacity
    • VS Internal Font Manager Dependent on 3rd Party Font Manager
      7505
      @Boldline said in VS Internal Font Manager Dependent on 3rd Party Font Manager: folders contained 30k fonts each Yes, this may cause slowdowns.
    • One stylus pen issue fixed - can this second issue also be fixed?
      8053
      @VectorStyler Thank you - I know you'll find the best solution. I appreciate you hearing me out
    • Difficulty adding node to existing path with double click
      4296
      @VectorStyler so far is always been a literal double tap, but I will try adding that function to a stylus button and see how that goes. I agree the stylus overall is less precise and using a stylus button might help in multiple ways
      How to break a connexion between clone objects
      12611
      How to Edit Text Background?
      • gotanidea
      5019
      @VectorStyler said in How to Edit Text Background?: @b77 @gotanidea The modal character options editor has a bug when working with background / underline and other decorators. Some drop downs don't open. The fix for these will be in the next build. Good to know that. Thanks again
    • More Keyboard Shortcut Conflicts
      25
      25
      28173
      @Igull
      Rendering artifacts with VS
      13109
      @Harry Can be replicated.
    • T
      width dialogs
      • ti
      2682
      T
      @VectorStyler Thanks for getting on it. Looking forward to the next build!
    • T
      shape paint and gaps
      • ti
      5876
      T
      @VectorStyler Thanks for confirming there's a bug. Another issue that might be related is that the "Close Shapes" value in the "Shape Paint Options" dialog does not persist. It gets reset back to the same very small value whenever the dialog is closed and re-opened. @b77 That's a slick workaround you came up with!
      Trace B/W shape without white
      • postdes
      6207
      @postdes 'Ignore White' is the correct setting for this, not 'Extract Alpha'. My apologies.
      Transparent Backgrounds?
      • jeff43222
      5671
      Ahh! That's what I was looking for! I think I was thrown by the term "grid" since I usually think of the grid as a separate design guide element than the background. Thanks!
    • Reset Transform
      4155
      @Igull
      Canvases, artboards, clones, actions - designs for Redbubble
      3221
      @VectorStyler Thanks for this comprehensive answer! Still a long way ahead, but when I master references I feel like i could be great shortcut.
    • How to I make sure Favorite Fonts display?
      3364
      @Boldline You didn't by any chance click the 'Favorite Font' entry in the Character panel's menu? That is a checkmark, and if you click it, the font is deleted from the Favorites list.
      How to draw "calligraphic" strokes with a stylus?
      2669
      @Harry Looks like the width profile goes through too much simplification in VS, for long paths. I will improve this.
      Blends are not automatically transferred to cloned curves
      4232
      @VectorStyler said in Blends are not automatically transferred to cloned curves: @Subpath Just duplicating, or cloning the two ends will not carry the blend over. This is by design. that it does not work with duplicates is clear to me if I manually blend the cloned curves it works as desired but that the blending is not automatically is transferred to the cloned curves, if i blend the two orinal curves had me just wondered.
      Converting a tutorial from Illustrator (Blend Function) to VectorStyler
      • fewerjunk
      12911
      I got this, by grouping the finished blend which made it easier to rotate (from the center I think vs from an edge). Quite a bit of tinkering. Not a bad result. Thanks for the help. 0_1670487017668_Abstract_Knot_Illus_Vctr_FINAL.vstyler
    • Disabling vertical flipping during text scaling?
      4261
      @encart I added this to the backlog, will do flipping only if both directions are flipped. @Boldline No option for this.
      Trim and Join and .... Extend (once again)
      3671
      @VectorStyler said in Trim and Join and .... Extend (once again): @Harry Should it work for lines only, or for curves also? It would really need to work for curves too - that'll make it easier for you Neil
