    the last item cut and saved to memory is not retained if history panel is used to go back to a step prior
    2 Posts 2 Posters 2.8k Views 1 Watching
      I don't know if this is a bug or just the way VS operates, but it seems the last item cut and essentially saved to memory is not retained if history panel is used to go back to a step prior to it being cut.
      So in this example, I changed the font choice of some live text and then cut it. then I went back several steps long before I swapped the text font and then pasted what was in memory. I would have expected the newly cut font to be pasted there, not the old one at that point.
      It does seem to work properly with objects and the like - so it might just be a live font thing?
        @Boldline THis looks like a bug. I will try to replicate and fix it.
