      Wrong object position when pasting on new layer
      • mtinra
      7063
      @b77 for me if I put back the old files, it go wrong again. It may has somthing else on my machine to trigger the problem
    • Question about saving symbols
      • visualrevolt
      3917
      @visualrevolt said in Question about saving symbols: I would like to see something similar to AD. When you drag and drop symbol it stays in the library. These are called presets in VectorStyler. You can create a symbol preset using the Presets panel. And these will be available in other documents also.
      Questions about creating and using a new color palette
      4298
      @VectorStyler thank you for the guidance will follow your advice
      Live paint/shape paint
      • Sarah Austen
      11112
      @Sarah-Austen said in Live paint/shape paint: @Subpath any news/progress on the bug? these are questions for @VectorStyler (he already answered ) I am just a normal user like you
      Printing paper orientation
      2178
      @Harry This seems to be a bug, added it to the backlog.
    • Clarifying settings
      3981
      @Boldline said in Clarifying settings: There's also a setting on that sets my rotation of an object to designated amounts. it feels like the snapping it on but it's not... If I take an object and grab a corner with the transform tool and try to rotate it, it's not a smooth rotation. I hope that makes sense Is it Prefs > Editing Options 1 > Angle Constraint? This value is for rotating with Shift.
      Repeater : what do I do wrong ?
      51
      51
      108335
      @VectorStyler as I found it easier to define a symbol through the Symbol panel, I understand why I could rarely get the expected results... a somewhat tricky bug
    • R
      Align Object Size command is also moving the objects
      • Raven
      2346
      @Raven Added this to the backlog. Looks the there is a problem with the scaling center.
    • T
      Problem Viewing or Setting UISTYLER MODE To Light Mode
      • trialkw1000
      5640
      @VectorStyler i do not use a high DPI screen therefore I have never heard of such a possibility but will have a look around
    • How to turn off default grid on new projects
      2378
      @Boldline That document settings changes the grid color only. Currently, the grid visibility is not persistent to the next new document, but it has been in the past. Which means, that a visible Grid mode is stored in the settings.xml files and it is always on. The only way to turn it off for default is to start with the new settings file (or remove from an existing one, but there is no UI for that).
    • Were objects dragged into a VS from outside sources set to be links by default now?
      21
      21
      23608
      @William-Kansepa Thanks. Maybe 'Embed Linked File' is the right word for this instead of 'Expand'. Besides that, it should help both AI and AD users make the connection. (I'm also not sure the Styles menu is the right location for it)
    • Object counter tool tip not showing in last two builds
      4732
      @b77 I set the workspace back to the default and the selection counter resumed working properly. I'll send you the workspace file @VectorStyler
    • Moving Text Frames
      5788
      @Igull The problem can be replicated. It is caused by the corner handles that were enabled for the transform tool. Will be fixed.
      "xml:" is missing before name attribute in SVG-File
      3232
      @VectorStyler , thanks
    • Support for webp images
      2255
    • R
      Corner styles for selected nodes
      • Raven
      2665
      @Raven There seems to be a bug here with the selection of corner styles. I added this to the backlog.
      "Contour" panel
      3082
      @Pat The fix will be in the build, it was a minor regression.
    • Using gradient in stroke does not allow for copy and paste or other adjustments
      3707
      @Boldline said in Using gradient in stroke does not allow for copy and paste or other adjustments: Removing the customized preferences file did solve the issue Send me the custom pref file if this issue occurs again. It might be some settings that causes this.
    • Convert objects to lines ?
      7720
      @Igull your welcome ...BTW, what is your native language ??... my native language is german ...Don't you just love VS !!!!... Of course, that's why we are here I know that .wmf works in this way from the time I worked professionally and had to somehow import the strangest file formats into Corel Draw for further processing
    • the last item cut and saved to memory is not retained if history panel is used to go back to a step prior
      2422
      @Boldline THis looks like a bug. I will try to replicate and fix it.
