    • Drag Object to Scroll
      3048
      Neil
    • Workspace Locking ?
      3619
      @b77 said in Workspace Locking ?: (You didn't use the search field under the Help menu? ) I did, but I wasn't looking for the word 'panel', I was looking for workspace Neil
    • Any way to move 2 selected anchor points in opposite direction?
      • syllie
      7332
      @syllie said in Any way to move 2 selected anchor points in opposite direction?: Step wise interactive change would have been nice I added this to the feature request backlog.
    • How did I create this 2nd artboard?
      • syllie
      6775
      @syllie said in How did I create this 2nd artboard?: Select artwork + RMB click with artboard tool creates a new artboard This part could be a bug. Will be fixed ASAP.
    • Magic Wand Selection & composite shape
      • syllie
      2193
      @syllie Can be replicated. This seems to be a bug, will be fixed ASAP.
    • Cannot assign shortcut for Select -> Select Similar -> Fill Color ?
      • syllie
      7266
      @syllie Yes, those are not separate actions. I will try to improve this for 1.2
      Am wondering if there's a way to assign two different shortcuts to a single command? e.g. Zoom to Artboard I could choose to use Control+0 or Control+0 (from the numeric pad).
      shortcut keys • • William Kansepa
      5311
      @syllie Yes, it is in the backlog and not yet implemented.
    • Auto-snapping a shape to 90 degrees keeps shape from being rotated freely
      2965
      @VectorStyler ok no problem. Thanks for the explanation. I'm glad this is fixed and improved upon already for a future update. Sounds like it will be a real game-changer when it's officially released. I can make do for now until then.
    • Text on path aligned to "ascent" leaves large gap at top between words and path
      3528
      @vectorstyler @b77 thank you both for explaining. That makes sense now.
      Unintentional Opacity in a Noise Gradient
      8026
      @Subpath it should work with Software at least in all cases, so this might be a bug unrelated to the GPU.
    • Can PDFs be exported from VS with layers honored?
      3591
      @VectorStyler ok no problem. It's not an urgent thing. In the long term it would be a great addition to add layers to PDF because it would give VS an alternative export with layers option besides strictly native VS files.
      Colorize: Randomize dose not included the last color in palette
      • mtinra
      2841
      In this case, it should be a random deselected but it could be anything, a new selection mode or a new tool or command but it is not high priority. Thanks
    • "Reselect" tool purpose?
      6966
      @Boldline Agree, no need to make it an entirely new option. It would in essence be a Reselection of the last Deselected / Dropped regular selection set. Regardless of how the Selection set was established. So Reselect would be active from a "No Selection" status. It would act like "Undoing" a Deselection, as @b77 described.. /Lars
    • Align does not always seem to do the right thing
      3165
      @Boldline Can be replicated here also, it is a bug.
      Status bar show wrong information.
      • mtinra
      2092
      @mtinra This seems to be a bug, and can be replicated here also. Added it to the backlog.
      Weird behavior when repeating duplicate with a rotated object.
      • Gremriel
      6110
      @syllie said in Weird behavior when repeating duplicate with a rotated object.: But I believe the behaviour is not correct. I agree, this looks like a bug, added it to the backlog.
      Context panel: how to reorganize
      4041
      @Subpath @Boldline Thank you both for your replies. I'm on W & it is under View > Customize...
      Setup new document in pexels unit, got the wrong artboard size
      • mtinra
      2379
      @mtinra Added this to the backlog.
      Second chance for pick a key object in alignment
      • mtinra
      4025
      @mtinra said in Second chance for pick a key object in alignment: Sorry for flooding the board. Feel free to post as many ideas, bugs and questions as you have on the forum. I have personally benefited from many questions and answers as well as the suggestions others have brought up over the time I've been using Vectorstyler. What I appreciate most is the way the developer, @VectorStyler truly listens to the ideas presented and considers their implementation as well as fast turnaround on bug reports and the like.
      Click on layer widget should not active layers rename
      • mtinra
      2233
      @mtinra Yes, there is a small bug here when, clicking on the layer name after clicking away should not start editing. The way it was intended is that if the layer name is clicked again (not yet a double click) then it should open for editing. This will be fixed ASAP. As for the double click editing: that can be enabled using the Layer panel menu Panel Options command, with the Double Click Renames checkbox (bottom-right).
