    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
    • Moving text on a path is not easy
      5597
      @encart said in Moving text on a path is not easy: I added these issues to the backlog. Is it possible to just drag&drop the text to the other side of the path? By pressing the space key. Is it possible to place a copy of the text on other path by Alt Key + drag&drop? yes, this should work by dragging close to the outline of that path.
    • Pdf exports messed up type
      3491
      @Raaskot Interesting, thanks for letting me know. Seems to be a font "option" error when embedding the font into the PDF.
    • Unexpected Results when Merging Shapes
      • debraspicher
      2778
      @debraspicher The retracted handles at the end of the path cause a stroke glitch. The union seems to be correct, but the stroke at that bottom node is wrong. I will try to find a solution for this.
    • Live text cannot be erased with command-x and copying with command-c does not work either
      2475
    • Object that is set to "lock" still allows opacity change so long as it is still selected
      1936
    • Gradient Color Presets menu issues
      • nocturnalYL
      3052
      @nocturnalYL said in Gradient Color Presets menu issues: That means only the 1st point remains applicable I will try to fix this for the next build.
      SVG Import seems to be broken
      7408
      @Ingolf This gradient issue is not yet fixed and it did exist before also. I will try to find a solution for this.
      path extension tool
      • monsterfox
      3039
      @VectorStyler Thank you for the fix.You are so great.
    • Stroke size indicator on the screen sometimes gets stuck
      1847
      Hidden graphics can still be selected by the magic wand tool.
      • monsterfox
      4999
      a bug
      • monsterfox
      1808
      @monsterfox said in a bug: The cursor will still appear in the input field. I will try to find a solution for this. In some cases the editing will remain active after confirmation.
    • Deselecting a path made with the path tool does not usually work on first click with command modifier
      3237
      @Raven I will try to replicate this, seems to be a bug.
    • Missing?
      • Ayo
      1825
      @Ayo I will add this to the backlog, but I'm not sure yet if it will be changed.
    • Node Tool Not Deselecting Objects Immediately when clicking on Artboard
      2726
      @Boldline Can be replicate here also.
      three errors
      • monsterfox
      5517
      @VectorStyler Post question 3: At that time, due to the absence of video, you misunderstood. The function of incremental transformation of each has been lost, and it is hoped to restore the function. In addition, there is this checkbox in the transformation panel, but it seems to have no effect. I hope to check it. Thank you.
    • Character tool not allowing rotation
      2785
      @Boldline Got it, it could be caused by the selection node scaling settings.
    • Show text cursor above text frame almost correct
      • Ayo
      2315
      @Ayo said in Show text cursor above text frame almost correct: In my opinion, default blinking speed could be a little tiny bit faster? Get a sluggish feeling... I agree with this, the speed should be increased some
      Color and other palette inconsistencies with macos workspaces
      • jpsimmons
      6307
      @jpsimmons The screenshot was not uploaded for some reason. Please do a clean install of VS (including removing the user files from the Help -> Reveal Workspace folder).
    • Does VS necessarily have to close open unsaved files to be able to check for an build update?
      3418
      @Boldline I will try doing that. I think the problem was with the type of exit used by the Sparkle updater, I have to check that.
    • Clicking on artboard using the shift modifier deselects what was already selected
      2840
      @Boldline @larsherold it is a regression.
