    3. VectorStyler 1.2 beta
      "Keep Locked with Artboard" issue
      • larsherold
      3297
      @larsherold I will address this issue in the next build
    • C
      BUG - PANELS ON EXTERNAL MONITOR IN SLEEP MODE
      • colorweber
      3741
      @colorweber Thanks for reporting this issue, and welcome to VectorStyler. I opened a bug on this external monitor issue, and will try to fix it as soon as possible.
    • Color swatch separator frame
      • Ayo
      5441
      @debraspicher said in Color swatch separator frame: I like this quite a bit. Can be enabled with the Color Palette panel menu -> Display -> Show Grid Margin
      The Super Ellipse producing too many nodes when converted to curves
      • William Kansepa
      3790
      @William-Kansepa I got 16 nodes with the default curvature. But it might be more with other parameters. Send me a file with the super ellipse shape that has too many nodes when converted to curves. I will try to improve this, but super-ellipses are difficult to approximate with beziers.
      Some Select sub-menus under the Select menu misfiring
      • William Kansepa
      5520
      @VectorStyler Thank you!
      Gradient Flip Colours not working
      • William Kansepa
      3145
      @William-Kansepa Can be replicated here also. This is a bug, and will be fixed for the next build
    • Programme behaving weirdly
      • ambros
      5942
      @ambros You can manually delete the crash files in x:\ProgramData\NumericPath\Crash Logs\
      Up-down arrow for numeric values not working
      • jkwchui
      7172
      @jkwchui I noticed this too and yes, it's giving the impression that we can micromanage increment the field, not pull up the slider.
      Convert to Curves: OpenType SVG One-to-Many Incorrectly Expanded
      • jkwchui
      3391
      @jkwchui Can you send me a VS file with that text (before expansion) using the font. I assume that this is the VF-Canto font.
      Regression: Colour Picker failing to copy colour from images
      • William Kansepa
      2637
      @William-Kansepa Download and install again by removing the current version. I added this fix a bit too late, and there was no version increase for automatic update.
      Animated panels?
      • William Kansepa
      4478
      @VectorStyler Sent to your email. Thank you.
      Importing and placing images faults
      • William Kansepa
      5560
      @William-Kansepa said in Importing and placing images faults: After importing and dragging an image into VS, the program somehow shifts the intended position and thereby fails to maintain x and y coordinates of the placed image. Placing images is now working as expected in VS 1.2.0.25. X and Y coordinates are now being maintained after clicking and dragging. Thank you @VectorStyler!
      Shape Paint irregularities
      • William Kansepa
      3355
      So far so good in VS 1.2.0.25. The Shape Paint objects are updating perfectly after transforming. Thank you @VectorStyler!
      Scaling artwork/text from the centre is a hit-and -miss
      • William Kansepa
      2763
      @William-Kansepa I think the difference (to other apps) might be that in VS you have to press the Control after the scaling started. Also: it is possible to customize the key in Preferences -> Modifier Keys -> "Centered Adjustment" row.
      Corrupted files after exporting / pasting
      • William Kansepa
      6395
      @William-Kansepa said in Corrupted files after exporting / pasting: Exporting artboard at 300dpi is working, but at 400dpi the previous challenge still persists I will try to replicate this.
      Canvas Guidelines duplicated in panel
      • William Kansepa
      2533
      @William-Kansepa I added this to the backlog.
      Assigning a fill colour to a text frame
      10822
      @VectorStyler I forgot to mention that it is fine with the Transparency/Color panels (same values). It is only the Appearance panel that is not showing any effect.
      Image Limit Cannot be Set Below 8 MB When Exporting
      • gotanidea
      2985
      @gotanidea I opened a bug on this one.
    • Transform Selection Node sizes
      • Ayo
      6794
      @VectorStyler Mac Studio + Studio Display 27" default resolution, macOS ventura 13.4.01
      Right Alt (AltGr) acts like Control key while in Text Tool
      5714
      @VectorStyler In my case, everything is currently working as it should. Edit: I don't know why , but now, have the same issue as @Harry. Just opened browser to write post here than returned to VS and since that have to use shortcut twice. Edit 2: Ok, I know why it worked in my case. AltGR + Letter works properly only for the first character in text field - any further require double use. I was typing 'Ą' , than delete and typing 'Ć' and so on.
