Odd text spacing in imported svg file
When I open an svg file (not created in Vector Styler) in Vector Styler 1.2.35, spacing between letters in text is not correct. Some letters are too close together, others too far apart. The same file opened in Inkscape 1.3.2 does not show the same problem. The same file opened in Affinity Designer 2.5.3 does not show the same problem. The font is Times New Roman and all results are on the same machine.
@pmFrench Hello, and welcome to VectorStyler.
Please send me the file by email to csraba at vectorstyler.com (or upload to the forum if possible).
I will try to find out what could cause this issue. -
@pmFrench Got the file, the problem can be replicated.
Thank you for the fix.
