    3. VectorStyler 1.2 beta
      Issue with offset?
      2918
      @VectorStyler I've sent you the file with this specific object
    • UI, Theme
      3565
      @861475_VctSt I will review "Flat Dark".
      Gradient panel: not visible
      4187
      @VectorStyler It is fine now, I can display or hide the panel.
    • Regression
      3027
      @861475_VctSt I can replicate the issue. It is only in the beta, (1.1.110 does not have this regression). The earlier fix was done in the resources of the 1.1 fork only and forgot to check that in to 1.2 also. Fix will be in the next build
      Blend panel
      2141
      @Pat Will fix this ASAP.
    • JIS paper size
      2099
      Paragraph styles
      3165
      @VectorStyler file sent. Thanks
      Artboard layout - issue with snapping to guides
      2203
      @Pat Got the file, and opened a bug on this one.
    • Horizontal orange temporary guide line when moving objects, the horizontal line seems thinner than the others
      3089
      @Boldline I cannot replicate this here on retina.
    • Is resetting the workspace to default supposed to also set the settings to default?
      2632
      @Boldline I will test this, normally it should not reset the settings.
    • Could custom shape applied to erase tool also work when cursor is moving?
      1804
      @Boldline No, only for click erase and when holding Option(Alt) key to start erasing.
    • Add an option to shrink the panels to JUST the icons themselves? sans words?
      2670
      @Boldline It seems that the issue occurs only when the panels are docked.
    • Add option to font manager to add existing live fonts in document to document level save
      3419
      @Boldline said in Add option to font manager to add existing live fonts in document to document level save: what does VS do currently when it opens a saved file that has live fonts within? Yes, it scans the fonts from the document. This is OK to do once at startup. But as the document changes it will need to do again. It is not enough to just remember the font changes. The problem is that it will not know if a font change overwrites some other font or it is a new font.
    • Shrinking panels to icons does not always place the panels flush to the right side
      2141
      @Boldline yes, there are some issues when the panels are docked.
    • Allow settings panel to be sized by user - also add scroll bar for topics
      3912
      @b77 oh ok i see what you mean with the transparency now. I like that and agree that should be added for greater clarity of what section title is selected
      Suggestion: delete "recent documents"
      1625
      @Pat yes, added this to the backlog.
