    3. VectorStyler 1.2 beta
      Impossible to give a stroke value to blended objects
      7025
      @VectorStyler The bug is fixed... Thanks for this rapid update & fix
      Settings: retain certain values
      31
      31
      42552
      @Pat said in Settings: retain certain values: Still there when I reduce some panels. I could not replicate this yet. Send me the workspace and settings files from the /resources/ folder
      Autofill option under guidelines panel
      • Kumr
      3914
      @VectorStyler I restarted my system and that setting disappeared. No clue what happened. Will check on Mac Utility part. Thanks
    • Unable to use 'Shift' to extend selection
      • Ayo
      5839
      @Ayo said in Unable to use 'Shift' to extend selection: Works, but I have to start from scratch again. Changing my settings It could be that some of these settings changes caused the Shift+ issue. So next time the Shift+ problem occurs, just zip all those files in the resources folder (they contains the user settings and the workspace customizations) and send them to me.
    • Nodes, Name of artboard and corners of warp tools seem oversized
      3022
      @Boldline Looks normal here (also 27"). I will test on a macbook pro. Are there some settings that were changed related to Node or Screen scaling?
    • Release to Layers (seq.), designed this way?
      • Ayo
      3162
      @Ayo I opened a task on this one. Lets see what is the feedback.
      • Ayo
    • Shape/Frame Text not accept 'Paste' text
      • Ayo
      2481
      @Ayo It is a bug, will be fixed ASAP.
      The shapes flew out
      • Li Xiao
      3408
      @VectorStyler This bug has been fixed also. Thank you.
      Looks like a bug in the Bending
      • Li Xiao
      3460
      @VectorStyler This bug has been fixed. Thank you.
    • Typography 2: 'Auto' is a relative value
      • Ayo
      9033
    • Typography 1: Paragraph Leading
      • Ayo
      10533
      @Ayo said in Typography 1: Paragraph Leading: Still want me to stay connected? Absolutely. I know VS is a bit of an acquired taste I'm a bit slow today, preparing the new build (will take some time).
    • Typography
      • Ayo
      4713
      @Ayo said in Typography: Should I report other issues ? Yes
    • Convert Text to ...
      • Ayo
      2684
      @Ayo said in Convert Text to ...: Convert to what? It converts between shape and frame text. I will add a better (automatic) naming based on the selection.
    • Text-trouble
      • Ayo
      5304
      @Ayo said in Text-trouble: Should be resolved anyway. Yes, it is a bug.
    • Crash Report misses 'Send'
      • Ayo
      9573
      @Ayo said in Crash Report misses 'Send': Are they automatically deleted after a real save? yes they should be
    • Layers panel 'preview drag and drop' switch working?
      • Ayo
      3503
      @VectorStyler Thank you. Then it works. Divider could maybe use some contrast?
    • Delete one swatch color group, group disappears
      • Ayo
      4383
      @Ayo said in Delete one swatch color group, group disappears: In grid mode is it nearly impossible to recognise you are dealing with a group! A mistake in the Light UI theme
      Impossible to trace with Pen tool
      10225
      @Li-Xiao I managed to replicate this issue. The fix will be in the next build.
    • Snap to Points doesn't seem to work
      • Ayo
      22
      22
      33272
      @Subpath said in Snap to Points doesn't seem to work: works pretty well Indeed! And another point for the Node Tool! (my favourite default) Thanks!
