Knife tool not always working when an object is not selected
Trying out the knife tool today with build 32, there are times it will not always slice through an un-selected fill object - but at other times it will. It will always work if the target shape is pre-selected.
@Boldline I've had a problem with the knife for a while. In the case of an ellipse, it usually only creates points on the edge. Knife is much better at rectangles, but there are cases when I want to cut with several lines and the last cut erases the previous.
@Boldline I tried the knife tool on an un-selected object and it seems to be working here. in some cases the result needs a "break apart".
If there is an example case that could help replicate this, please send it by email.
@vectoradmin This is what it looks like in my case. Have similar issues as @Boldline
https://recordit.co/2ya6h1KvCs
@encart I tried again so I could send a file and video to @vectoradmin and it was less noticeable this time around... earlier in my video, some of the cut lines did not seem to register until after a small delay and at the very end, it was cutting one section but not another. it seems more random now as to when it will cut or not
@Boldline In my case, it behaves almost the same. It rarely works properly, never in an ellipse. Additionally, I noticed that Eraser tool is also infected. After one pass, the selection of the object disappears and the eraser stops working. It is necessary to select again.
@encart I will try to replicate this, here it works on ellipses.
