      Adding a Shape Effect - button has died
      • A Former User
      14307
      @plrang This problem should be fixed in 1.1.049, now it is not possible to remove the default folders.
    • expanding a stroke moves it into an unwanted position
      4305
      @Boldline This problem should be fixed in 1.1.049 A note: the stroke width might still change when the stroke is inside a transformed group. I will try to find a solution for that
      Toolbox Style - change 1 to 2 columns issue
      • A Former User
      3647
      Font search input: adding a Font to Favorites doesn't work
      • A Former User
      3184
    • Eraser Tool Healing Open Path
      10983
      @Igull This problem should be fixed in 1.1.049
    • Object to Object Snapping Issue
      8286
      @Igull The node to point (and shape) snapping feature is added in build 1.1.049
    • New From Template Broken
      3765
    • Cannot disable HEX color from main prefs
      4052
      @Ingolf This problem should be fixed in 1.1.049
    • Unusual selection box when dragging a copy of a vector with option modifier
      7893
    • Custom color palette bar issues
      2955
      @Boldline Is this problem still persists?
    • Font Family Font Weights Missing
      • Victor Vector
      21
      21
      34008
      @Victor-Vector Is this problem with the font weights still persists?
    • Not be possible to select multiple vector shapes that have an affect applied to them and then paste them in together
      3799
    • Create Artboard: Landscape option glitching.
      • Victor Vector
      4520
      @Victor-Vector I will keep this issue open.
    • Am I too tired... or is difficult to reduce length of rotated, duplicated elements
      5180
      @Ingolf This problem should be fixed in build 1.1.048
    • Color panel range distance is too large for editing colors
      2884
      @Boldline This is caused by the color panel being resizable, and automatically resizing when docked.
    • Cut and Pasted Text does not retain current attributes
      6616
      @Boldline This problem should be fixed in build 1.1.048
    • Tooltips in panels no longer shown after one button activation (Win port)
      4915
      @Ingolf This problem should be fixed in recent builds of VS
    • Editing an object with a reference breaks instant preview
      7037
      @Ingolf Redrawing of reference (original and copy) while editing should be improved in new builds.
    • Codepage used in tooltips not the same as in layer names
      3990
      @Ingolf This problem should be fixed in more recent builds of VS.
    • Vectorstyler Takes over all Memory and Space
      4450
      @Boldline There were improvements to the memory use of some actions in build 1.1.048
