    • Marked objects misleading when previewing combine
      2681
      @Ingolf Yes, this seems to be a (temporary) highlight update issue with the Layers panel. Added it to the backlog as a bug.
    • "separate at intersections" does not seem to be working properly for me
      3855
      @Boldline yes, this can be replicated on a similar case (the two points are close). I will try to fix this ASAP.
    • Eraser Tool on Filled Object
      5513
      @Igull Thanks for the inside information. It is always interesting for me to hear other use cases. My profession was digital printing but we also had some plotters for cutting foil. But I have always been interested in areas that are related in the broadest sense. So I know a thing or two about laser cutting. My team leader once brought some very impressive samples from a print show. For example, an apple with a laser cutting Motif on it.
    • Docked alignment panel has spacing issue when "Alignment options" is clicked to be added
      3306
      @Boldline Yes, this is a bug, can be replicated easily.
    • Switching to pen tool while "Draw Inside" is active causes switch to "Draw on Top"
      4204
      @Boldline @Devil-Dinosaur Yes, this can be replicated easily and the root cause is identified. Will try to fix it ASAP. EDIT: as a workaround, double click to isolate and then draw.
    • Preset manager bit of a nightmare
      • Dazmondo
      8695
      @VectorStyler Great - now getting my head around it
    • Unable to change colour profiles
      • Dazmondo
      8342
      @b77 said in Unable to change colour profiles: @VectorStyler So if in Document Setup > Color tab you leave the 'Color' option at 'Default CMYK' there is no profile assigned and the app uses the profile set in 'Styles > Color Settings? And if you choose 'CMYK' instead and one of the available profiles from the 'CMYK' menu that pops up under it, that one will be used and not whatever is set in Styles > Color Settings? Yes, that is how it supposed to be.
    • New from Template Issue
      4617
      @VectorStyler No problem, sounds like a good idea ! Neil
    • Offset path preview seems to default to lowered opacity on first click
      2617
    • Weird rulers
      • Dazmondo
      25
      25
      33562
      @VectorStyler An elegant solution could be to integrate this choice invisibly into a Start Window, where if the user chooses a web size artboard/preset document (say, 960x1600px), it creates it with top-down coordinates.
    • Some Distortion tools not working
      • Dazmondo
      22
      22
      32323
      The next bug fix build release is hereby dedicated to @Dazmondo for the numerous recent Bug discoveries both intentional and the inadvertent! Special thanks to @VectorStyler for hitting clean-up
    • Wacom stylus has trouble clicking a second time on checkbox in offset path panel
      4400
      @VectorStyler Sharing related examples of difficulties related to issues with the settings for the stylus on VS. Very often it is difficult to get the stylus to select an existing node to move and edit it. You can see in the video examples of my attempts to click on an existing node and move it. I have better luck in the middle of the video and repeated failures at the end. The issue happens often in every project I work in. The more zoomed out I am, the more likely it will not select the node as it should - the more I zoom in, the more likely it will work as expected.
    • undocked color panel goes away after a period of time
      2301
    • Objects are not maintaining their active selection when pasted - (live text works)
      3984
      Have a curious extra stroke scaling
      5230
      I wonder if it might be worth having a command that applies the reverse transform to the stroke itself and toggles the option, so that the current size of the stroke is maintained and the option is applied from that point forward? That way both behaviors could be supported.
    • Object created with pen tool not selected after it is created
      3868
      @Ingolf Not directly related, but possibly helpful: If the first thing you want to do after finishing a path is editing its nodes, you can do it by holding down the Cmd key which switches to shape editing mode. Then releasing it reverts to the Pen tool.
      Clones doesnt work as Clones if i change Fill Color of a Clone
      3601
      @Subpath Could be a regression. I think it is. I added this to the backlog and will try to replicate it. Thanks
    • Crash when switching from another app.
      3382
      @VectorStyler Is there some additional window manager or other tool installed on MacOS? No, other than the normal option of having multiple desktops (spaces) available - which I use. Generally allocating a single app to a desktop - keeps everything tidy. However, currently, VS is on the same desktop as Safari. Command+TAB is one easy way to get to another app (you can use Mission Control - again, part of the OS and not a separate app as such), the OS just displays a horizontal panel of apps - click on one to go there. Neil
      SVG imports as text
      • freggern
      2699
      @freggern Yes, this can be replicated here also. Added it to the backlog.
    • Nodes invisible when hovering
      21
      21
      30010
      @Igull Great!
