expanding a stroke moves it into an unwanted position
I'm not sure if this is related to the surfboard being tilted in between processes, but when I went to expand the stroke, it moved it to a new unwanted location - am I missing something?
When I cut the shape and paste it behind, it also wants to paste in an odd location
I attached the file below
@Boldline As a workaround, if you take it outside the group it converts correctly.
@Boldline Yes, this can be replicated. Another workaround for this is to use Convert to Curves on the whole group, before expanding a stroke inside the group.
Will be fixed ASAP.
@Boldline This problem should be fixed in 1.1.049
A note: the stroke width might still change when the stroke is inside a transformed group.
I will try to find a solution for that
