Open PDF Broken
Looks like opening a PDF is broken, it just opens an empty document (at the correct PDF scale I should add ) you can create an empty document and import a PDF, but that still annoyingly resizes the imported PDF to fit the document and isn't at the original PDF scale, so not a proper workaround
Of course, that's not to say I haven't missed the RTFM update in the interim
Neil
@Igull Opening a few PDFs here just now and it works here. All PDFs fail to open there?
@b77
I just went through a pile of them here to test, some open with an empty doc area and the PDF to the RHS of the artboard, most open with just an empty doc area (correctly sized) and no data.
The PDFs can all import OK (with the annoying resizing to the doc limits as stated )TBH, the ones that open with the empty doc area and data to the right are simply TIF files that have been saved as PDF - the rest (the ones that don't show any data) are true vector files that have been exported as PDF.
If Csaba needs them, I'll forward a few as examples to him.
It's only a wee bit annoying for now as I do know they're the incorrect size and I can check and scale them manually.
Neil
@Igull Yes, I would send a few of them to the developer and you can download the previous version from https://vectorstyler.com/releaselog/
@Igull In Preferences -> Document Files enable the "Open PDF on Canvases" option.
Looks like the multi-page PDF opening still has some issues.
@VectorStyler said in Open PDF Broken:
Looks like the multi-page PDF opening still has some issues.Nope, still doesn't work
I can send a few docs if needed ?
Neil
@b77 said in Open PDF Broken:
Might need to send some, yes, we'll see. However, I'll stick with 068 for now as the snapping issue has been fixed
I know the scales, so can just do an import to open any PDF's.
Neil
@Igull This issue should be fixed in the new build 1.1.072
