Created brush presets won't show up in the "Brush presets" panel
Let the pictures speak...
@Nils The Brush Presets panel should not be empty, even if all other presets are removed.
It should have the "Presets" group label showing.
Got to the Brush Presets panel menu and see if there is a Reveal Hidden Presets option. If so, select it, because it could be that the Presets group was hidden (clicking the (x) next to it will hide it not remove it).
@vectoradmin Clicking this option did show the presets and from there I could also successfully delete the leftover presets, which then also disappeared from the brush selector. So, both problems solved.
May I suggest that clicking the X folds the group instead of completely hiding it. This would likely avoid this confusion.
@Nils said in Created brush presets won't show up in the "Brush presets" panel:
The group can be folded with the arrow. The problem is that if I want a panel showing only a single group, than the others should be hidden.
