Select grouped tools in the toolbox.
When I want to open the select menu for grouped tools in the toolbox, it open only when I "long" click on it. When I click on the right bottom triangle of the corner it doesn't open the submenu. (Don't know if its a windows version problem, only)
@freggern Problem exists on Mac also. I will try to fix this issue.
@freggern Clicking on the arrow should open immediately in build 1.1.008
thx, tested!
Supplement: It looks like you can't select sometimes an item in the grouped tool because it close the select menu to fast. Looks like by long click it open the select menu. On the arrow it looks like there is a mouseout event trigger and close the submenu. When you not fast enaugh in the submenu, the submenu will be closed.
@freggern said in Select grouped tools in the toolbox.:
Supplement: It looks like you can't select sometimes an item in the grouped tool because it close the select menu too fast.
Can confirm here also.
@freggern Replicated, will get fixed.
@freggern This problem should be fixed now.
There is sometimes some strange short close und reopen behavior (looks like a timed event that happend after some time)
