• The advantage of spot colors
    @VectorStyler said in The advantage of spot colors: color also contains the tint That should stay that way, right? At least that's how AI taught me, keep the tint value. This is the desired result for clarity (made it one by one, not all at once). [image: 1730387960757-add85fa1-7b82-42d2-af78-6e6dae2b32a3-image-resized.png]
  • Copy and paste to VS
    @VectorStyler yes, but not all the attributes have been kept, and the design is less perfect.
  • How to get out of this loop?
    @Ayo said in How to get out of this loop?: Is this kind of editing not allowed at spotcolors? Not directly from the color panel, unless expanded into CMYK first (that color icon under the tint number field). To edit the spot color without expanding, double click on it in the color palette.
  • Brush(work), inconsistency in design
    @Pat Send me that file, could be that the corners are breaking.
  • SVG import pixel to point conversion
    @VectorStyler said in SVG import pixel to point conversion: Yes, the problem Got it... (a little) Remember that the problem can also be on the other side. In other words; the SVG output of Qgis can also contain imperfections or errors. Still strange that ai6 does work against all common opponents. I wonder what Freehand would do but I don't have that working under the buttons anymore. Thanks for investigating
  • Transformed stroke & Uniform stroke scaling
    @VectorStyler Ok, thanks! I need this functionality to continue with VS, and it seems useful to be able to measure the thickness of the strokes after readjusting the object(s).
  • points snapping
    @monsterfox said in points snapping: When using the straight - line tool, some angles cannot snap to points and will be offset. Can be replicated, it is a bug (also snaps to the angle of the other shape and it should not). I will try to fix this issue, and improve the point snapping mode.
  • Reorganising objects aligned along a stroke?
    @Pat said in Reorganising objects aligned along a stroke?: I thought that aligning objects along a stroke allowed me to reorganise the whole by modifying the stroke nodes No the objects are not linked to the stroke, if the shape is changed, you must align again. could the History panel specify the type of alignment used I added this to the features backlog (will be done, but later). I would like the (long) axis of the ellipses follow the stroke shape. Possible ? If the "Rotate Path" checkbox is selected in the Blend panel (or panel menu), the ellipse will be rotated according to the direction of the path.
    @Boldline Yes, and it is implemented and part of the Apple Silicon and Intel releases (not in the Universal release due to some XCode issue). Still an open issue while it does not work.
  • Bug and improvement?
    @Ayo This is a regression in the past 2 versions
    @VectorStyler Thanks for looking into that and finding a solution for now and in the next build.
  • node editing tool
    @VectorStyler I just tested CorelDRAW again, and the result was the same as that of Inkscape and Designer.
  • Color Picker + cmd modifier
    @Ayo said in Color Picker + cmd modifier: For consistency and to please ex Illustrator customers it would be nicer in my opinion to use cmd+ for Drawing Tools for positioning and sizing I will try to change this after the next build
  • Auto-trigger Path/Node Options
    @debraspicher Should the preview for these node commands be a separate option ?
  • Auto reset transformation
    @Ayo said in Auto reset transformation: Disable for the time being? Yes.
  • repeat
    @VectorStyler I usually have a relatively large workload, and most of it involves repetitive operations. Therefore, I will try my best to reduce the operations as much as possible. Typing with the keyboard will invisibly add some amount of operations (and directly using "Larger nudging" is faster).
  • Data Sources - how to import " (quotation mark)
    @Harry This is a bug, the root cause was identified and the fix will be in the next build.
  • How to skip empty artboards while exporting?
    @Harry said in How to skip empty artboards while exporting?: It's a bit confusing now. I think it would be clearer if the "Export Artboard" panel didn't show excluded (empty) artboards. The way it works now: the artboard export settings can be saved and recalled as presets and also using the Export Again. If the the content of the artboards is changed, the "Export Again" will also adapt to the new empty/used artboards, if they were selected.
  • Uniform Stroke Scaling problem
    @Ayo said in Uniform Stroke Scaling problem: Why lives"Transform Content" and other transform options well, in the appearance menu anyway? These are options of the style items listed in the Appearance panel.
  • "Magnetic node tool" available in VS?
    @VectorStyler That's nice, thanks With liquid-tool/magnetic I find options I need: Interactive control of fall-off/"brush"-size and the option to transform node clusters without adding new segments. Very useful when adjusting shapes to a background sketch without metriculously tracing it segment by segment [image: 1728468719111-e6249b90-4f7c-499f-b3e2-9f98077a33f5-billede-resized.png]
